CCS/TMDXEVM368: Settings to connect JTAG to CPU on TMDXEVM368 with XDS200
Guru 16800 points
Part Number: TMDXEVM368
Please let me know how to connect JTAG to CPU on TMDXEVM368 with XDS200.
With default settings, XDS510 works fine; however, XDS200 doesn't work and the following message is shown.
Error connecting to the target:
(Error -2131 @ 0x0)
Unable to access device register. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK).
(Emulation package 6.0.504.1)
Now, I'm using CCS v7.0.
Nomo
  • Hi Nomo,
    What configuration are you setting for XDS200 ?
    What is your device type and connection while setting the target configuration?
    Anuj
    Pathpartner Technology Pvt  Ltd.
  • Hi Anuj-san,
    Thank you for your reply.
    I attach the target configuration file and the settings for XDS200.
    2260.EVMDM368.txt
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <configurations XML_version="1.2" id="configurations_0">
    <configuration XML_version="1.2" id="Texas Instruments XDS2xx USB Debug Probe_0">
            <instance XML_version="1.2" desc="Texas Instruments XDS2xx USB Debug Probe_0" href="connections/TIXDS2XXUSB_Connection.xml" id="Texas Instruments XDS2xx USB Debug Probe_0" xml="TIXDS2XXUSB_Connection.xml" xmlpath="connections"/>
            <connection XML_version="1.2" id="Texas Instruments XDS2xx USB Debug Probe_0">
                <instance XML_version="1.2" href="drivers/tixds560icepick_c.xml" id="drivers" xml="tixds560icepick_c.xml" xmlpath="drivers"/>
                <instance XML_version="1.2" href="drivers/tixds560arm9.xml" id="drivers" xml="tixds560arm9.xml" xmlpath="drivers"/>
                <instance XML_version="1.2" href="drivers/tixds560etb11.xml" id="drivers" xml="tixds560etb11.xml" xmlpath="drivers"/>
                <platform XML_version="1.2" id="platform_0">
                    <instance XML_version="1.2" desc="EVMDM368_0" href="boards/evmdm368.xml" id="EVMDM368_0" xml="evmdm368.xml" xmlpath="boards"/>
                </platform>
            </connection>
        </configuration>
    </configurations>
    Nomo
    Have you gone thorugh this post : e2e.ti.com/.../1453929
    I can solve the problem.
    Nomo
