I 'm using custom tablet board Omap3evm Dm3730 with Android ICS 4.0 Stack , after building the File system Bluetooth is not enable , How to change Bluetooth port
UART 3 instead of UART 1 because we are using Uart 3 .baudrate is 115200we using wl1271 chipset .
Note :WiFi is Working
Could please help to solve this issueLU
OPTIONS: I18n
Compiled on Aug 28 2012, 12:11:59.
Port /dev/ttyUSB0
Press CTRL-A Z for help on special keys
In: serial
Out: serial
Err: serial
Read back SMSC id 0xffff0000
Die ID #251400029ff80000016842c81602702a
Net: No ethernet found.
Hit any key to stop autoboot: 0
mmc1 is available
reading boot.scr
458 bytes read
Running bootscript from mmc ...
## Executing script at 82000000
reading uImage
3533960 bytes read
***** Kernel: /dev/mmcblk0p1/uImage *****
***** RootFS: /dev/mmcblk0p2 *****
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-2.6.37-g5c414d7-dirty
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3533896 Bytes = 3.4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 2.6.37-g5c414d7-dirty (root@atulkumar-desktop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #8 Mon Oct 22 15:12:51 IST 2012
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: OMAP3 EVM
[ 0.000000] Reserving 8388608 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630 ES1.2 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 62976
[ 0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootdelay=1 init=/init ip=off omaM
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 248MB = 248MB total
[ 0.000000] Memory: 243604k/243604k available, 18540k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0041000 ( 228 kB)
[ 0.000000] .text : 0xc0041000 - 0xc06c1000 (6656 kB)
[ 0.000000] .data : 0xc06c2000 - 0xc0714640 ( 330 kB)
[ 0.000000] NR_IRQS:409
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/400/600 MHz
[ 0.000000] Reprogramming SDRC clock to 400000000 Hz
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] GPMC revision 5.0
[ 0.000000] Trying to install interrupt handler for IRQ402
[ 0.000000] Trying to install interrupt handler for IRQ403
[ 0.000000] Trying to install interrupt handler for IRQ404
[ 0.000000] Trying to install interrupt handler for IRQ405
[ 0.000000] Trying to install interrupt handler for IRQ406
[ 0.000000] Trying to install interrupt handler for IRQ407
[ 0.000000] Trying to install interrupt handler for IRQ408
[ 0.000000] Trying to install type control for IRQ409
[ 0.000000] Trying to set irq flags for IRQ409
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 597.64 BogoMIPS (lpj=2334720)
[ 0.000000] pid_max: default: 32768 minimum: 301
[ 0.000000] Security Framework initialized
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] regulator: core version 0.5
[ 0.000000] regulator: dummy:
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.000000] omap3evm: bt init
[ 0.000000] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.000000] OMAP DMA hardware revision 5.0
[ 0.029663] bio: create slab <bio-0> at 0
[ 0.031005] regulator: vwl1271: 1800 mV
[ 0.032684] SCSI subsystem initialized
[ 0.035430] usbcore: registered new interface driver usbfs
[ 0.035827] usbcore: registered new interface driver hub
[ 0.036071] usbcore: registered new device driver usb
[ 0.045471] omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
[ 0.059356] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.059387] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.059936] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.065826] regulator: VIO: 1800 mV normal standby
[ 0.066589] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
[ 0.067321] regulator: VDAC: 1800 mV normal standby
[ 0.068023] regulator: VAUX2_4030: 2800 mV normal standby
[ 0.068756] regulator: VPLL2: 1800 mV normal standby
[ 0.069549] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
[ 0.070281] regulator: VAUX3: 2800 mV normal standby
[ 0.084533] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 0.100158] omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
[ 0.102050] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.102935] Bluetooth: Core ver 2.15
[ 0.103149] NET: Registered protocol family 31
[ 0.103149] Bluetooth: HCI device and connection manager initialized
[ 0.103179] Bluetooth: HCI socket layer initialized
[ 0.103668] Switching to clocksource 32k_counter
[ 0.232818] WL1271: BT_EN GPIO initialized
[ 0.233062] musb-hdrc: version 6.0, otg (peripheral+host), debug=0
[ 0.233215] musb-hdrc musb-hdrc.0: dma type: dma-inventra
[ 0.233551] musb-hdrc musb-hdrc.0: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 0.234161] NET: Registered protocol family 2
[ 0.234375] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.234802] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.235015] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.235168] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.235198] TCP reno registered
[ 0.235198] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.235229] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.235443] NET: Registered protocol family 1
[ 0.235778] RPC: Registered udp transport module.
[ 0.235809] RPC: Registered tcp transport module.
[ 0.235809] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.236022] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.243530] omap3evm camera init done successfully...
[ 0.243804] omap-iommu omap-iommu.0: isp registered
[ 0.244110] AM37x/DM37x Linux PSP version 04.02.00.07 (OMAP3EVM)
[ 0.410186] ashmem: initialized
[ 0.410675] VFS: Disk quotas dquot_6.5.2
[ 0.410766] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.412292] JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 0.412963] msgmni has been set to 475
[ 0.414398] io scheduler noop registered
[ 0.414398] io scheduler deadline registered
[ 0.414550] io scheduler cfq registered (default)
[ 0.471191] OMAP DSS rev 2.0
[ 0.471282] OMAP DISPC rev 3.0
[ 0.471313] OMAP VENC rev 2
[ 0.471618] OMAP DSI rev 1.0
[ 0.801177] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.803680] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 1.469604] console [ttyO0] enabled
[ 1.473693] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 1.481506] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.489288] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
[ 1.508361] brd: module loaded
[ 1.517303] loop: module loaded
[ 1.521545] (stk) :sysfs entries created
[ 1.525726] (stk) : debugfs entries created
[ 1.532653] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.539642] omap2-nand driver initializing
[ 1.544342] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xb3 (Micron )
[ 1.551330] Creating 5 MTD partitions on "omap2-nand.0":
[ 1.556945] 0x000000000000-0x000000080000 : "X-Loader-NAND"
[ 1.564880] 0x000000080000-0x0000001c0000 : "U-Boot-NAND"
[ 1.572631] 0x0000001c0000-0x000000280000 : "Boot Env-NAND"
[ 1.580291] 0x000000280000-0x000000780000 : "Kernel-NAND"
[ 1.589660] 0x000000780000-0x000040000000 : "File System - NAND"
[ 2.021667] OneNAND driver initializing
[ 2.025817] omap2-onenand omap2-onenand: Cannot request GPMC CS
[ 2.032073] omap2-onenand: probe of omap2-onenand failed with error -16
[ 2.040802] smsc911x: Driver version 2008-10-21.
[ 2.046203] usbcore: registered new interface driver asix
[ 2.052093] usbcore: registered new interface driver cdc_ether
[ 2.058441] usbcore: registered new interface driver net1080
[ 2.064575] usbcore: registered new interface driver cdc_subset
[ 2.070983] usbcore: registered new interface driver zaurus
[ 2.077056] usbcore: registered new interface driver zd1201
[ 2.082946] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.089904] ehci-omap.0 supply hsusb0 not found, using dummy regulator
[ 3.103790] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.109802] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 3.117706] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 3.135223] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.141326] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.148468] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.156066] usb usb1: Product: OMAP-EHCI Host Controller
[ 3.161651] usb usb1: Manufacturer: Linux 2.6.37-g5c414d7-dirty ehci_hcd
[ 3.168701] usb usb1: SerialNumber: ehci-omap.0
[ 3.174499] hub 1-0:1.0: USB hub found
[ 3.178497] hub 1-0:1.0: 3 ports detected
[ 3.213409] Initializing USB Mass Storage driver...
[ 3.218841] usbcore: registered new interface driver usb-storage
[ 3.225189] USB Mass Storage support registered.
[ 3.230285] usbcore: registered new interface driver usbtest
[ 3.236236] android init
[ 3.238983] android_probe pdata: c06d2eac
[ 3.243377] android_bind
[ 3.246795] android_usb gadget: android_usb ready
[ 3.251739] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 3.257385] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 3.265289] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.272430] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.280029] usb usb2: Product: MUSB HDRC host driver
[ 3.285247] usb usb2: Manufacturer: Linux 2.6.37-g5c414d7-dirty musb-hcd
[ 3.292297] usb usb2: SerialNumber: musb-hdrc.0
[ 3.298065] hub 2-0:1.0: USB hub found
[ 3.302062] hub 2-0:1.0: 1 port detected
[ 3.307006] f_adb init
[ 3.309478] android_register_function adb
[ 3.313690] f_mass_storage init
[ 3.317047] fsg_probe pdev: c06d2aa8, pdata: c06d2f3c
[ 3.322601] android_register_function usb_mass_storage
[ 3.328002] adb_bind_config
[ 3.331970] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.339233] android_usb gadget: Number of LUNs=1
[ 3.344085] lun0: LUN: removable file: (no medium)
[ 3.349517] f_mtp init
[ 3.351989] android_register_function mtp
[ 3.356842] mice: PS/2 mouse device common for all mice
[ 3.363342] input: TWL4030 Keypad as /devices/platform/omap/omap_i2c.1/i2c-1/1-004a/twl4030_keypad/input/input0
[ 3.378051]
[ 3.378051] WRITE FAILED 1
[ 3.382690]
[ 3.382690] WRITE SUCCESS 1
[ 3.387298]
[ 3.387298] WRITE SUCCESS 1
[ 3.391876]
[ 3.391906] WRITE SUCCESS 1
[ 3.396545]
[ 3.396545] WRITE SUCCESS 1
[ 3.401214]
[ 3.401214] WRITE SUCCESS 1
[ 3.405792]
[ 3.405822] WRITE SUCCESS 1
[ 3.410461]
[ 3.410461] WRITE SUCCESS 1
[ 3.415039]
[ 3.415039] WRITE SUCCESS 1
[ 3.419708]
[ 3.419708] WRITE SUCCESS 1
[ 3.424346]
[ 3.424346] WRITE SUCCESS 1
[ 3.428924]
[ 3.428955] WRITE SUCCESS 1
[ 3.433532]
[ 3.433563] WRITE SUCCESS 1
[ 3.438140]
[ 3.438140] WRITE SUCCESS 1
[ 3.442932]
[ 3.442932] WRITE SUCCESS 1
[ 3.447662]
[ 3.447662] WRITE SUCCESS 1
[ 3.452239]
[ 3.452239] WRITE SUCCESS 1
[ 3.456848]
[ 3.456878] WRITE SUCCESS 1
[ 3.461456]
[ 3.461486] WRITE SUCCESS 1
[ 3.466125]
[ 3.466125] WRITE SUCCESS 1
[ 3.470703]
[ 3.470733] WRITE SUCCESS 1
[ 3.475372]
[ 3.475372] WRITE SUCCESS 1
[ 3.479980]
[ 3.479980] WRITE SUCCESS 1
[ 3.484588]
[ 3.484588] WRITE SUCCESS 1
[ 3.489227]
[ 3.489227] WRITE SUCCESS 1
[ 3.493804]
[ 3.493835] WRITE SUCCESS 1
[ 3.498474]
[ 3.498474] WRITE SUCCESS 1
[ 3.503082]
[ 3.503082] WRITE SUCCESS 1
[ 3.507659]
[ 3.507690] WRITE SUCCESS 1
[ 3.512298]
[ 3.512298] WRITE SUCCESS 1
[ 3.516876]
[ 3.516876] WRITE SUCCESS 1
[ 3.521423] usb 1-1: new high speed USB device using ehci-omap and address 2
[ 3.528900]
[ 3.528900] WRITE SUCCESS 1
[ 3.533569]
[ 3.533569] WRITE SUCCESS 1
[ 3.538146]
[ 3.538146] WRITE SUCCESS 1
[ 3.542785]
[ 3.542785] WRITE SUCCESS 1
[ 3.547363]
[ 3.547393] WRITE SUCCESS 1
[ 3.552001]
[ 3.552001] WRITE SUCCESS 1
[ 3.556640]
[ 3.556640] WRITE SUCCESS 1
[ 3.561279]
[ 3.561279] WRITE SUCCESS 1
[ 3.565917]
[ 3.565917] WRITE SUCCESS 1
[ 3.570495]
[ 3.570495] WRITE SUCCESS 1
[ 3.575103]
[ 3.575134] WRITE SUCCESS 1
[ 3.579895]
[ 3.579895] WRITE SUCCESS 1
[ 3.584503]
[ 3.584503] WRITE SUCCESS 1
[ 3.589111]
[ 3.589111] WRITE SUCCESS 1
[ 3.593688]
[ 3.593688] WRITE SUCCESS 1
[ 3.598297]
[ 3.598327] WRITE SUCCESS 1
[ 3.602966]
[ 3.602966] WRITE SUCCESS 1
[ 3.607604]
[ 3.607604] WRITE SUCCESS 1
[ 3.612243]
[ 3.612243] WRITE SUCCESS 1
[ 4.133819] input: ssd2531_input as /devices/virtual/input/input1
[ 4.141021] input: 7k_ffa_keypad as /devices/virtual/input/input2
[ 4.149108] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input3
[ 4.162536] using rtc device, twl_rtc, for alarms
[ 4.167388] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 4.174346] twl_rtc twl_rtc: Power up reset detected.
[ 4.179962] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[ 4.187011] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.195343] twl_rtc twl_rtc: Enabling TWL-RTC.
[ 4.200592] hub 1-1:1.0: USB hub found
[ 4.204833] hub 1-1:1.0: 4 ports detected
[ 4.209320] i2c /dev entries driver
[ 4.214904] Linux media interface: v0.10
[ 4.219482] Linux video capture interface: v2.00
[ 4.225433] omap3isp supply VDD_CSIPHY1 not found, using dummy regulator
[ 4.232513] omap3isp supply VDD_CSIPHY2 not found, using dummy regulator
[ 4.239776] omap3isp omap3isp: Revision 15.0 found
[ 4.244842] omap-iommu omap-iommu.0: isp: version 1.1
[ 4.307861] mt9t111 2-003c: Unable to detectmt9t111sensor
[ 4.314453] isp_register_subdev_group: Unable to register subdev mt9t111
[ 4.321868] i2c i2c-3: Failed to register i2c client tvp5146m2 at 0x5c (-16)
[ 4.329315] isp_register_subdev_group: Unable to register subdev tvp5146m2
[ 4.337280] usbcore: registered new interface driver uvcvideo
[ 4.343322] USB Video Class driver (v1.0.0)
[ 4.348541] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 4.355438] device-mapper: uevent: version 1.0.3
[ 4.360870] device-mapper: ioctl: 4.18.0-ioctl (2010-06-29) initialised: dm-devel@redhat.com
[ 4.369842] Bluetooth: HCI UART driver ver 2.2
[ 4.374511] Bluetooth: HCI H4 protocol initialized
[ 4.379547] Bluetooth: HCILL protocol initialized
[ 4.384490] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 4.390655] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[ 4.398529] cpuidle: using governor ladder
[ 4.402893] cpuidle: using governor menu
[ 4.410003] mmci-omap-hs.1 supply vmmc_aux not found, using dummy regulator
[ 4.419616] usbcore: registered new interface driver usbhid
[ 4.425506] usbhid: USB HID core driver
[ 4.430358] logger: created 64K log 'log_main'
[ 4.435485] logger: created 256K log 'log_events'
[ 4.440948] logger: created 64K log 'log_radio'
[ 4.446014] logger: created 64K log 'log_system'
[ 4.452117] usbcore: registered new interface driver snd-usb-audio
[ 4.460144] OMAP3 EVM SoC init
[ 4.527893] usb 1-1.4: new full speed USB device using ehci-omap and address 3
[ 4.550231] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 4.557067] asoc: wl1271bt <-> omap-mcbsp-dai.0 mapping ok
[ 4.565399] ALSA device list:
[ 4.568511] #0: omap3evm
[ 4.571350] oprofile: hardware counters not available
[ 4.576690] oprofile: using timer interrupt.
[ 4.581359] nf_conntrack version 0.5.0 (3806 buckets, 15224 max)
[ 4.588195] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.593902] TCP cubic registered
[ 4.597320] Initializing XFRM netlink socket
[ 4.602203] NET: Registered protocol family 10
[ 4.607604] IPv6 over IPv4 tunneling driver
[ 4.612976] NET: Registered protocol family 17
[ 4.617675] NET: Registered protocol family 15
[ 4.622650] Bluetooth: L2CAP ver 2.15
[ 4.626525] Bluetooth: L2CAP socket layer initialized
[ 4.631896] Bluetooth: SCO (Voice Link) ver 0.6
[ 4.636688] Bluetooth: SCO socket layer initialized
[ 4.641815] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.647430] Bluetooth: BNEP filters: protocol multicast
[ 4.652954] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.659606] Registering the dns_resolver key type
[ 4.664581] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 4.673034] ThumbEE CPU extension supported.
[ 4.683624] Power Management for TI OMAP3.
[ 4.694000] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52e
[ 4.701263] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.709014] usb 1-1.4: Product: USB Receiver
[ 4.713531] usb 1-1.4: Manufacturer: Logitech
[ 4.718872] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 4.727203] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 4.735748] SmartReflex Class3 initialized
[ 4.744201] clock: disabling unused clocks to save power
[ 4.750762] platform iva.0: omap_voltage_scale: Already at the requestedrate 800000000
[ 4.759124] platform mpu.0: omap_voltage_scale: Already at the requestedrate 1000000000
[ 4.773223] input: Logitech USB Receiver as /devices/platform/ehci-omap.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input4
[ 4.784240] generic-usb 0003:046D:C52E.0001: input: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-ehci-omap.0-1.4/input0
[ 4.803283] input: Logitech USB Receiver as /devices/platform/ehci-omap.0/usb1/1-1/1-1.4/1-1.4:1.1/input/input5
[ 4.814605] generic-usb 0003:046D:C52E.0002: input: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-ehci-omap.0-1.4/input1
[ 4.895202] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 4.903808] omap_vout omap_vout: Buffer Size = 3686400
[ 4.923065] omap_vout omap_vout: : registered and initialized video device 15
[ 4.930572] omap_vout omap_vout: Buffer Size = 3686400
[ 4.936950] omap_vout omap_vout: : registered and initialized video device 16
[ 4.944610] mmc0: new high speed SDHC card at address e624
[ 4.950927] Waiting 1sec before mounting root device...
[ 4.956604] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[ 4.975830] mmcblk0: p1 p2 p3
[ 5.100891] mmc1: card claims to support voltages below the defined range. These will be ignored.
[ 5.126831] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 5.143035] mmc1: new SDIO card at address 0001
[ 5.973480] EXT3-fs: barriers not enabled
[ 5.978668] kjournald starting. Commit interval 5 seconds
[ 5.984436] EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
[ 6.015045] EXT3-fs (mmcblk0p2): using internal journal
[ 6.020507] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 6.027740] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 6.034057] Freeing init memory: 228K
[ 6.059204] init: /init.rc: 269: invalid command 'echo'
[ 6.064727] init: /init.rc: 270: invalid command 'echo'
[ 6.070190] init: /init.rc: 271: invalid command 'echo'
[ 6.075653] init: /init.rc: 272: invalid command 'sleep'
[ 6.081207] init: /init.rc: 273: invalid command 'echo'
[ 6.086639] init: /init.rc: 274: invalid command '//'
[ 6.093261] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 6.233123] init: cannot open '/initlogo.rle'
[ 6.302337] Compat-wireless backport release: compat-wireless-2011-12-05-1-g84dbe2c
[ 6.310363] Backport based on wl12xx.git v2.6.39-1328-g0890f48
[ 6.384063] cfg80211: Calling CRDA to update world regulatory domain
[ 6.580963] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 6.642181] enabling adb
[ 6.645812] adb_open
[ 6.875549] cfg80211: World regulatory domain updated:
[ 6.880981] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 6.889709] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 6.897979] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 6.906219] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 6.914489] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 6.922760] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
root@android:/ # [ 8.287780] init: untracked pid 1171 exited
[ 15.172393] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[ 21.795257] request_suspend_state: wakeup (3->0) at 22004058840 (2000-01-01 00:00:17.393066407 UTC)
[ 21.995147] init: no such service 'hciattach'
[ 21.999877] (stc): st_register(2)
[ 22.003295] (stc): chnl_id list empty :2
[ 22.007598] (stk) : st_kim_start
[ 22.010955] plat_kim_chip_enable
[ 22.069763] (stk) :ldisc_install = 1
[ 22.446350] wl1271: loaded
[ 23.072601] plat_kim_chip_enable
[ 23.078613] (stk) :ldisc_install = 1
[ 23.370056] wl1271: firmware booted (Rev 6.3.6.0.79_2)
[ 23.375427] wl1271: Driver version: R4_SP2_03_00
[ 23.390686] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 24.080413] plat_kim_chip_enable
[ 24.113952] (stk) :ldisc_install = 1
[ 24.690856] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 24.760223] wl1271: Association completed.
[ 25.111816] plat_kim_chip_enable
[ 25.125427] (stk) :ldisc_install = 1
[ 26.127380] plat_kim_chip_enable
[ 26.133911] (stk) :ldisc_install = 1
[ 27.135192] plat_kim_chip_enable
[ 27.168518] (stk) :ldisc_install = 1
root@android:/ #
[ 28.166442] ti_st_open: st_register failed -22
[ 28.274536] (stc): st_register(2)
[ 28.277954] (stc): chnl_id list empty :2
[ 28.282226] (stk) : st_kim_start
[ 28.285614] plat_kim_chip_enable
root@android:/ #
[ 28.438751] (stk) :ldisc_install = 1root@android:/ #
root@android:/ #
root@android:/ # l
[ 29.439788] plat_kim_chip_enable
[ 29.470245] (stk) :ldisc_install = 1og
[ 30.471099] plat_kim_chip_enable
[ 30.487396] (stk) :ldisc_install = 1cat
--------- beginning of /dev/log/main
I/DEBUG ( 1168): debuggerd: Oct 18 2012 15:29:43
E/uim-sysfs( 1166): uim: Inside main
E/uim-sysfs( 1166): uim:ST built into the kernel ?
E/uim-sysfs( 1166): uim:BT driver module un-available...
E/uim-sysfs( 1166): uim:BT driver built into the kernel ?
E/uim-sysfs( 1166): uim:FM driver module un-available...
E/uim-sysfs( 1166): uim:FM driver built into the kernel ?
E/uim-sysfs( 1166): uim:GPS driver module un-available...
E/uim-sysfs( 1166): uim:GPS driver built into the kernel ?
E/uim-sysfs( 1166): uim:FM V4L2 driver module un-available...
E/uim-sysfs( 1166): uim:FM V4L2 driver built into the kernel ?
E/uim-sysfs( 1166): uim:found bluetooth rfkill entry @ 0
E/uim-sysfs( 1166):
E/uim-sysfs( 1166): uim:changed permissions for /sys/class/rfkill/rfkill0/state(0)
E/uim-sysfs( 1166):
--------- beginning of /dev/log/system
I/Vold ( 1165): Vold 2.1 (the revenge) firing up
D/Vold ( 1165): Volume sdcard state changing -1 (Initializing) -> 0 (No-Media)
D/Vold ( 1165): Volume sdcard state changing 0 (No-Media) -> 2 (Pending)
D/Vold ( 1165): Volume sdcard state changing 2 (Pending) -> 1 (Idle-Unmounted)
I/Netd ( 1167): Netd 1.0 starting
E/Netd ( 1167): Unable to create netlink socket: Protocol not supported
E/Netd ( 1167): Unable to open quota2 logging socket
I/ ( 1172): ServiceManager: 0x18910
D/AndroidRuntime( 1171):
D/AndroidRuntime( 1171): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime( 1171): CheckJNI is ON
I/ ( 1173): ServiceManager: 0xf958
I/SurfaceFlinger( 1170): SurfaceFlinger is starting
I/SurfaceFlinger( 1170): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
E/audio_hw_primary( 1173): Route MIXER CTRL name: HeadsetR Mixer AudioR2
E/audio_hw_primary( 1173): Route MIXER CTRL name: HeadsetL Mixer AudioL2
E/audio_hw_primary( 1173): Route MIXER CTRL name: Headset Playback Volume
E/audio_hw_primary( 1173): Route MIXER CTRL name: Analog Left AUXL Capture Switch
E/audio_hw_primary( 1173): Route MIXER CTRL name: Analog Right AUXR Capture Switch
E/audio_hw_primary( 1173): Route MIXER CTRL name: Analog Capture Volume
I/AudioFlinger( 1173): Loaded primary audio interface from Omap3 audio HW HAL (audio)
I/AudioFlinger( 1173): Using 'Omap3 audio HW HAL' (audio.primary) as the primary audio interface
I/AudioFlinger( 1173): Loaded a2dp audio interface from A2DP Audio HW HAL (audio)
I/CameraService( 1173): CameraService started (pid=1173)
I/AudioFlinger( 1173): AudioFlinger's thread 0x15378 ready to run
W/AudioFlinger( 1173): Thread AudioOut_1 cannot connect to the power manager service
I/AudioPolicyService( 1173): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
E/FramebufferNativeWindow( 1170): couldn't open framebuffer HAL (Not a typewriter)
E/FramebufferNativeWindow( 1170): couldn't open gralloc HAL (Not a typewriter)
E/SurfaceFlinger( 1170): Display subsystem failed to initialize. check logs. exiting...
D/AndroidRuntime( 1261):
D/AndroidRuntime( 1261): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime( 1261): CheckJNI is ON
D/dalvikvm( 1261): Unable to stat classpath element '/system/framework/apache-xml.jar'
I/ethernet( 1261): Loading ethernet jni class
I/SamplingProfilerIntegration( 1261): Profiling disabled.
I/Zygote ( 1261): Preloading classes...
D/dalvikvm( 1261): GC_EXPLICIT freed 37K, 84% free 409K/2560K, paused 0ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 4K, 82% free 474K/2560K, paused 0ms+0ms
[ 31.486663] plat_kim_chip_enable
freed 20K, 81% free 509K/2560K, paused 1ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 27K, 80% free 537K/2560K, paused 0ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 15K, 78% fr[ 31.506134] (stk) :ldisc_install = 1ee 577K/2560K, paused 0ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 27K, 77% free 604K/2560K, paused 0ms+0ms
D/dalvikvm( 1261): GC_EXPLICIT freed 30K, 76% free 636K/2560K, paused 0ms+1ms
D/TextLayoutCache( 1261): Using debug level: 0 - Debug Enabled: 0
W/Zygote ( 1261): Class not found for preloading: android.media.AudioManager$2
I/dalvikvm( 1261): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI( 1261): register_android_mtp_MtpDevice
W/MediaProfiles( 1261): could not find media config xml file
W/Zygote ( 1261): Class not found for preloading: android.media.IRemoteControlClientDispatcher
W/Zygote ( 1261): Class not found for preloading: android.media.IRemoteControlClientDispatcher$Stub
D/dalvikvm( 1261): GC_EXPLICIT freed 20K, 74% free 675K/2560K, paused 0ms+1ms
D/dalvikvm( 1261): GC_FOR_ALLOC freed 217K, 63% free 970K/2560K, paused 8ms
D/dalvikvm( 1261): GC_EXPLICIT freed 43K, 60% free 1026K/2560K, paused 0ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 27K, 59% free 1055K/2560K, paused 1ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 8K, 57% free 1104K/2560K, paused 1ms+0ms
D/dalvikvm( 1261): GC_EXPLICIT freed 23K, 55% free 1170K/2560K, paused 1ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 48K, 44% free 1449K/2560K, paused 1ms+1ms
W/Zygote ( 1261): Class not found for preloading: android.text.TextDirectionHeuristics$CharCount
W/Zygote ( 1261): Class not found for preloading: android.text.method.WordIterator$1
D/dalvikvm( 1261): GC_EXPLICIT freed 35K, 43% free 1483K/2560K, paused 1ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 32K, 42% free 1505K/2560K, paused 1ms+1ms
I/dalvikvm( 1261): threadid=1: recursive native library load attempt (/system/lib/libwebcore.so)
D/dalvikvm( 1261): No JNI_OnLoad found in /system/lib/libchromium_net.so 0x0, skipping init
D/dalvikvm( 1261): GC_EXPLICIT freed 26K, 40% free 1554K/2560K, paused 2ms+2ms
W/Zygote ( 1261): Class not found for preloading: android.widget.EdgeGlow
D/dalvikvm( 1261): GC_EXPLICIT freed 25K, 39% free 1583K/2560K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 71K, 37% free 1628K/2560K, paused 2ms+2ms
E/PhonePolicy( 1261): Could not preload class for phone policy: com.android.internal.policy.impl.PhoneWindow$ContextMenuCallback
D/dalvikvm( 1261): GC_EXPLICIT freed 33K, 36% free 1650K/2560K, paused 1ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 28K, 35% free 1679K/2560K, paused 1ms+2ms
I/SurfaceFlinger( 1267): SurfaceFlinger is starting
I/SurfaceFlinger( 1267): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
D/libEGL ( 1267): loaded /system/lib/egl/libGLES_android.so
D/dalvikvm( 1261): GC_EXPLICIT freed 26K, 34% free 1709K/2560K, paused 6ms+3ms
D/libEGL ( 1267): loaded /system/lib/egl/libEGL_POWERVR_SGX530_125.so
D/dalvikvm( 1261): GC_EXPLICIT freed 32K, 33% free 1735K/2560K, paused 2ms+2ms
D/libEGL ( 1267): loaded /system/lib/egl/libGLESv1_CM_POWERVR_SGX530_125.so
D/libEGL ( 1267): loaded /system/lib/egl/libGLESv2_POWERVR_SGX530_125.so
W/SurfaceFlinger( 1267): ro.sf.lcd_density not defined, using 160 dpi by default.
D/dalvikvm( 1261): GC_EXPLICIT freed 31K, 32% free 1763K/2560K, paused 2ms+2ms
I/SurfaceFlinger( 1267): EGL informations:
I/SurfaceFlinger( 1267): # of configs : 30
I/SurfaceFlinger( 1267): vendor : Android
I/SurfaceFlinger( 1267): version : 1.4 Android META-EGL
I/SurfaceFlinger( 1267): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_base EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_rende
I/SurfaceFlinger( 1267): Client API: OpenGL ES
I/SurfaceFlinger( 1267): EGLSurface: 8-8-8-8, config=0x1
I/SurfaceFlinger( 1267): OpenGL informations:
I/SurfaceFlinger( 1267): vendor : Imagination Technologies
I/SurfaceFlinger( 1267): renderer : PowerVR SGX 530
I/SurfaceFlinger( 1267): version : OpenGL ES-CM 1.1
I/SurfaceFlinger( 1267): extensions: GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_matrix_get GL_OES_read_format GL_OES_compressed_palettet
I/SurfaceFlinger( 1267): GL_MAX_TEXTURE_SIZE = 2048
I/SurfaceFlinger( 1267): GL_MAX_VIEWPORT_DIMS = 2048 x 2048
I/SurfaceFlinger( 1267): flags = 00010000
W/SurfaceFlinger( 1267): hwcomposer module not found
D/dalvikvm( 1261): GC_EXPLICIT freed 71K, 29% free 1818K/2560K, paused 2ms+1ms
D/libEGL ( 1271): loaded /system/lib/egl/libGLES_android.so
D/libEGL ( 1271): loaded /system/lib/egl/libEGL_POWERVR_SGX530_125.so
D/libEGL ( 1271): loaded /system/lib/egl/libGLESv1_CM_POWERVR_SGX530_125.so
D/libEGL ( 1271): loaded /system/lib/egl/libGLESv2_POWERVR_SGX530_125.so
D/dalvikvm( 1261): GC_EXPLICIT freed 39K, 29% free 1834K/2560K, paused 2ms+39ms
I/System ( 1261): Loaded time zone names for in 519ms (514ms in ICU)
I/System ( 1261): Loaded time zone names for en_US in 352ms (348ms in ICU)
D/dalvikvm( 1261): GC_EXPLICIT freed 325K, 25% free 1944K/2560K, paused 1ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 15K, 22% free 2005K/2560K, paused 1ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 51K, 21% free 2036K/2560K, paused 1ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 28K, 20% free 2066K/2560K, paused 2ms+3ms
D/dalvikvm( 1261): GC_EXPLICIT freed 37K, 19% free 2083K/2560K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 32K, 18% free 2105K/2560K, paused 2ms+2ms
I/Zygote ( 1261): ...preloaded 2297 classes in 3653ms.
D/dalvikvm( 1261): GC_EXPLICIT freed 22K, 18% free 2110K/2560K, paused 2ms+2ms
I/Zygote ( 1261): Preloading resources...
D/dalvikvm( 1261): GC_EXPLICIT freed 1K, 16% free 2165K/2560K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 1K, 14% free 2216K/2560K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 3K, 12% free 2263K/2560K, paused 1ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 3K, 10% free 2310K/2560K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 4K, 8% free 2358K/2560K, paused 1ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 5K, 6% free 2408K/2560K, paused 1ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 4K, 7% free 2455K/2627K, paused 2ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 5K, 5% free 2501K/2627K, paused 1ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 4K, 6% free 2550K/2691K, paused 1ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 4K, 6% free 2599K/2755K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 5K, 6% free 2660K/2819K, paused 5ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 2K, 4% free 2709K/2819K, paused 1ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 3K, 5% free 2756K/2883K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 6K, 5% free 2804K/2947K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 7K, 4% free 2850K/2947K, paused 2ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 4K, 4% free 2899K/3011K, paused 1ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 9K, 3% free 2943K/3011K, paused 3ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 8K, 2% free 3022K/3075K, paused 2ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 5K, 3% free 3067K/3139K, paused 2ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 4K, 3% free 3117K/3203K, paused 1ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 4K, 2% free 3164K/3203K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 5K, 1% free 3240K/3267K, paused 1ms+3ms
D/dalvikvm( 1261): GC_EXPLICIT freed 4K, 3% free 3555K/3651K, paused 2ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed 7K, 2% free 3608K/3651K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 2K, 2% free 3658K/3715K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 5K, 2% free 3707K/3779K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 4K, 1% free 3881K/3907K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 3K, 2% free 3928K/3971K, paused 2ms+3ms
D/dalvikvm( 1261): GC_EXPLICIT freed 5K, 3% free 4988K/5123K, paused 1ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 5K, 4% free 6009K/6211K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 4K, 3% free 6058K/6211K, paused 3ms+3ms
D/dalvikvm( 1261): GC_EXPLICIT freed 7K, 2% free 6102K/6211K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 6K, 1% free 6149K/6211K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 5K, 1% free 6197K/6211K, paused 1ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 2K, 1% free 6249K/6275K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 4K, 1% free 6297K/6339K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 6K, 1% free 6358K/6403K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 3K, 1% free 6423K/6467K, paused 2ms+2ms
I/Zygote ( 1261): ...preloaded 379 resources in 1945ms.
D/dalvikvm( 1261): GC_EXPLICIT freed 20K, 2% free 6457K/6531K, paused 2ms+2ms
I/Zygote ( 1261): ...preloaded 31 resources in 42ms.
D/dalvikvm( 1261): GC_EXPLICIT freed 14K, 2% free 6460K/6531K, paused 2ms+2ms
D/dalvikvm( 1261): GC_EXPLICIT freed 6K, 2% free 6454K/6531K, paused 2ms+1ms
D/dalvikvm( 1261): GC_EXPLICIT freed <1K, 2% free 6454K/6531K, paused 1ms+2ms
I/dalvikvm( 1261): System server process 1276 has been created
I/Zygote ( 1261): Accepting command socket connections
E/BatteryService( 1276): acOnlinePath not found
E/BatteryService( 1276): usbOnlinePath not found
E/BatteryService( 1276): batteryStatusPath not found
E/BatteryService( 1276): batteryHealthPath not found
E/BatteryService( 1276): batteryPresentPath not found
E/BatteryService( 1276): batteryCapacityPath not found
E/BatteryService( 1276): batteryVoltagePath not found
E/BatteryService( 1276): batteryTemperaturePath not found
E/BatteryService( 1276): batteryTechnologyPath not found
I/sysproc ( 1276): Entered system_init()
I/sysproc ( 1276): ServiceManager: 0x155060
D/SensorService( 1276): nuSensorService starting...
E/SensorService( 1276): couldn't load sensors module (No such file or directory)
I/sysproc ( 1276): System server: starting Android runtime.
I/sysproc ( 1276): System server: starting Android services.
I/sysproc ( 1276): System server: entering thread pool.
I/SystemServer( 1276): Entered the Android system server!
I/SystemServer( 1276): Entropy Service
I/SystemServer( 1276): Power Manager
I/SystemServer( 1276): Activity Manager
I/ActivityManager( 1276): Memory class: 48
I/ActivityManager( 1276): Enabled StrictMode logging for AThread's Looper
I/SystemServ
[ 32.510131] plat_kim_chip_enable
er( 1276): Telephony Registry
I/SystemServer( 1276): Package Manager
D/dalvikvm( 1276): GC_CONCURRENT freed 312K, 6% free 6649K/7047K, paused [ 32.526489] (stk) :ldisc_install = 13ms+3ms
W/PackageManager( 1276): Running ENG build: no pre-dexopt!
W/PackageManager( 1276): Boot class path not found: /system/framework/apache-xml.jar
D/dalvikvm( 1276): GC_CONCURRENT freed 272K, 6% free 6772K/7175K, paused 3ms+2ms
E/StrictMode( 1276): A resource was acquired at attached stack trace but never released. See java.io.Closeable for information on avoiding resource leaks.
E/StrictMode( 1276): java.lang.Throwable: Explicit termination method 'close' not called
E/StrictMode( 1276): at dalvik.system.CloseGuard.open(CloseGuard.java:184)
E/StrictMode( 1276): at java.io.FileInputStream.<init>(FileInputStream.java:80)
E/StrictMode( 1276): at com.android.server.pm.UserManager.readUserList(UserManager.java:114)
E/StrictMode( 1276): at com.android.server.pm.UserManager.<init>(UserManager.java:81)
E/StrictMode( 1276): at com.android.server.pm.UserManager.<init>(UserManager.java:85)
E/StrictMode( 1276): at com.android.server.pm.PackageManagerService.<init>(PackageManagerService.java:923)
E/StrictMode( 1276): at com.android.server.pm.PackageManagerService.main(PackageManagerService.java:833)
E/StrictMode( 1276): at com.android.server.ServerThread.run(SystemServer.java:163)
D/StrictMode( 1276): No activity manager; failed to Dropbox violation.
W/PackageParser( 1276): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #125
D/dalvikvm( 1276): GC_CONCURRENT freed 146K, 4% free 7060K/7303K, paused 2ms+4ms
W/PackageManager( 1276): Package com.android.gallery3d desires unavailable shared library com.google.android.media.effects; ignoring!
W/PackageManager( 1276): Package com.android.camera desires unavailable shared library com.google.android.media.effects; ignoring!
D/dalvikvm( 1276): GC_CONCURRENT freed 199K, 5% free 7303K/7623K, paused 2ms+6ms
W/PackageParser( 1276): No actions in intent filter at /system/app/Contacts.apk Binary XML file line #525
D/PackageManager( 1276): No files in app dir /vendor/app
I/installd( 1175): new connection
I/Installer( 1276): connecting...
I/PackageManager( 1276): Time to scan packages: 3.329 seconds
W/PackageManager( 1276): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.contacts
W/PackageManager( 1276): Unknown permission android.permission.ADD_SYSTEM_SERVICE in package com.android.phone
W/PackageManager( 1276): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 1276): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 1276): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 1276): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager( 1276): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 1276): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.contacts
W/PackageManager( 1276): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cp in package com.android.providers.contacts
W/PackageManager( 1276): Unknown permission android.permission.READ_EXTERNAL_STORAGE in package com.android.videoeditor
W/PackageManager( 1276): Unknown permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD in package com.android.development
W/PackageManager( 1276): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.development
W/PackageManager( 1276): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.ALL_SERVICES in package com.android.development
W/PackageManager( 1276): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.YouTubeUser in package com.android.development
W/PackageManager( 1276): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x8be45)
D/dalvikvm( 1276): GC_CONCURRENT freed 328K, 6% free 7473K/7879K, paused 5ms+3ms
D/dalvikvm( 1276): GC_EXPLICIT freed 200K, 8% free 7330K/7943K, paused 2ms+2ms
I/SystemServer( 1276): Account Manager
D/PackageManager( 1276): generateServicesMap(android.accounts.AccountAuthenticator): 2 services unchanged
I/SystemServer( 1276): Content Manager
D/PackageManager( 1276): generateServicesMap(android.content.SyncAdapter): 4 services unchanged
I/SystemServer( 1276): System Content Providers
I/ActivityThread( 1276): Pub settings: com.android.providers.settings.SettingsProvider
D/SettingsProvider( 1276): cache for settings table 'secure' rows=36; fullycached=true
D/SettingsProvider( 1276): cache for settings table 'system' rows=51; fullycached=true
I/SystemServer( 1276): Lights Service
I/SystemServer( 1276): Battery Service
F/BatteryStatsImpl( 1276): problem reading network stats
F/BatteryStatsImpl( 1276): java.lang.IllegalStateException: problem parsing idx 1
F/BatteryStatsImpl( 1276): at com.android.internal.net.NetworkStatsFactory.readNetworkStatsDetail(NetworkStatsFactory.java:300)
F/BatteryStatsImpl( 1276): at com.android.internal.net.NetworkStatsFactory.readNetworkStatsDetail(NetworkStatsFactory.java:250)
F/BatteryStatsImpl( 1276): at com.android.internal.os.BatteryStatsImpl.getNetworkStatsDetailGroupedByUid(BatteryStatsImpl.java:5734)
F/BatteryStatsImpl( 1276): at com.android.internal.os.BatteryStatsImpl.doUnplugLocked(BatteryStatsImpl.java:1418)
F/BatteryStatsImpl( 1276): at com.android.internal.os.BatteryStatsImpl.setOnBatteryLocked(BatteryStatsImpl.java:4335)
F/BatteryStatsImpl( 1276): at com.android.internal.os.BatteryStatsImpl.setBatteryState(BatteryStatsImpl.java:4394)
F/BatteryStatsImpl( 1276): at com.android.server.am.BatteryStatsService.setBatteryState(BatteryStatsService.java:434)
F/BatteryStatsImpl( 1276): at com.android.server.BatteryService.processValues(BatteryService.java:252)
F/BatteryStatsImpl( 1276): at com.android.server.BatteryService.update(BatteryService.java:234)
F/BatteryStatsImpl( 1276): at com.android.server.BatteryService.<init>(BatteryService.java:148)
F/BatteryStatsImpl( 1276): at com.android.server.ServerThread.run(SystemServer.java:196)
F/BatteryStatsImpl( 1276): Caused by: java.io.FileNotFoundException: /proc/net/xt_qtaguid/stats: open failed: ENOENT (No such file or directory)
F/BatteryStatsImpl( 1276): at libcore.io.IoBridge.open(IoBridge.java:406)
F/BatteryStatsImpl( 1276): at java.io.FileInputStream.<init>(FileInputStream.java:78)
F/BatteryStatsImpl( 1276): at com.android.internal.net.NetworkStatsFactory.readNetworkStatsDetail(NetworkStatsFactory.java:269)
F/BatteryStatsImpl( 1276): ... 10 more
F/BatteryStatsImpl( 1276): Caused by: libcore.io.ErrnoException: open failed: ENOENT (No such file or directory)
F/BatteryStatsImpl( 1276): at libcore.io.Posix.open(Native Method)
F/BatteryStatsImpl( 1276): at libcore.io.BlockGuardOs.open(BlockGuardOs.java:110)
F/BatteryStatsImpl( 1276): at libcore.io.IoBridge.open(IoBridge.java:390)
F/BatteryStatsImpl( 1276): ... 12 more
D/dalvikvm( 1276): GC_CONCURRENT freed 245K, 5% free 7547K/7943K, paused 4ms+3ms
E/lights ( 1276): write_int failed to open /sys/class/leds/battery-led/brightness
I/SystemServer( 1276): Vibrator Service
I/power ( 1276): *** set_screen_state 1
I/SystemServer( 1276): Alarm Manager
I/SystemServer( 1276): Init Watchdog
I/SystemServer( 1276): Window Manager
I/InputManager( 1276): Initializing input manager
W/StatusBarManager( 1276): warning: no STATUS_BAR_SERVICE
E/OMXMaster( 1173): OMX plugin failed w/ error 0x80001001 after registering 0 components
I/InputManager( 1276): Starting input manager
I/SystemServer( 1276): Bluetooth Service
I/WindowManager( 1276): Enabled StrictMode logging for WMThread's Looper
I/BluetoothProfileState( 1276): Message:Entering Stable State
I/WindowManager( 1276): Enabled StrictMode for PolicyThread's Looper
D/EventHub( 1276): No input device configuration file found for device '7k_ffa_keypad'.
I/EventHub( 1276): New device: id=1, fd=95, path='/dev/input/event2', name='7k_ffa_keypad', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/Generic.kle
D/EventHub( 1276): No input device configuration file found for device 'ssd2531_input'.
I/EventHub( 1276): New device: id=2, fd=97, path='/dev/input/event1', name='ssd2531_input', classes=0x14, configuration='', keyLayout='', keyCharacterMap='', builtinKe
E/EventHub( 1276): could not get driver version for /dev/input/mice, Not a typewriter
D/EventHub( 1276): No input device configuration file found for device 'Logitech USB Receiver'.
I/EventHub( 1276): New device: id=3, fd=98, path='/dev/input/event5', name='Logitech USB Receiver', classes=0x80000149, configuration='', keyLayout='/system/usr/keylae
E/EventHub( 1276): could not get driver version for /dev/input/mouse0, Not a typewriter
I/EventHub( 1276): New device: id=4, fd=96, path='/dev/input/event4', name='Logitech USB Receiver', classes=0x80000003, configuration='', keyLayout='/system/usr/keylae
D/EventHub( 1276): No input device configuration file found for device 'TWL4030 Keypad'.
I/EventHub( 1276): New device: id=5, fd=99, path='/dev/input/event0', name='TWL4030 Keypad', classes=0x21, configuration='', keyLayout='/system/usr/keylayout/TWL4030_e
D/EventHub( 1276): No input device configuration file found for device 'twl4030_pwrbutton'.
I/EventHub( 1276): New device: id=6, fd=103, path='/dev/input/event3', name='twl4030_pwrbutton', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/Genere
I/InputReader( 1276): Device added: id=6, name='twl4030_pwrbutton', sources=0x00000101
I/InputReader( 1276): Device added: id=5, name='TWL4030 Keypad', sources=0x00000301
I/InputReader( 1276): Device added: id=4, name='Logitech USB Receiver', sources=0x00000101
I/InputReader( 1276): Device added: id=3, name='Logitech USB Receiver', sources=0x01002513
I/InputReader( 1276): Touch device 'ssd2531_input' could not query the properties of its associated display 0. The device will be inoperable until the display size.
I/InputReader( 1276): Device added: id=2, name='ssd2531_input', sources=0x00001002
I/InputReader( 1276): Device added: id=1, name='7k_ffa_keypad', sour
[ 33.525756] plat_kim_chip_enable
ces=0x00000101
D/BluetoothAdapterStateMachine( 1276): PowerOff process message: 5
I/SystemServer( 1276): Input Method Service
I/bluedroid( 1276): Starting hciattach daemon
[ 33.543975] (stk) :ldisc_install = 1W/InputManagerService( 1276): Couldn't create dir.: /data/system/inputmethod
W/ResourceType( 1276): Failure getting entry for 0x7f060000 (t=5 e=0) in package 0 (error -75)
I/InputReader( 1276): Reconfiguring input devices. changes=0x00000004
I/InputReader( 1276): Device reconfigured: id=2, name='ssd2531_input', surface size is now 1024x600, mode is 1
I/SystemServer( 1276): Accessibility Manager
I/ActivityManager( 1276): Config changed: {1.0 0mcc0mnc en_US layoutdir=0 sw600dp w1024dp h552dp lrg land ?uimode ?night finger qwerty/v/v dpad/v s.2}
D/PermissionCache( 1267): checking android.permission.ACCESS_SURFACE_FLINGER for uid=1000 => granted (732 us)
E/uim-sysfs( 1166): uim: Inside st_uart_config
E/uim-sysfs( 1166): uim:install set to 1
E/uim-sysfs( 1166): uim: Inside set_baud_rate
E/uim-sysfs( 1166): uim: Can't get port settings
E/uim-sysfs( 1166): uim: set_baudrate() failed
E/uim-sysfs( 1166): uim:cleanup
I/SystemServer( 1276): Device Policy
I/SystemServer( 1276): Status Bar
I/SystemServer( 1276): Clipboard Service
I/SystemServer( 1276): NetworkManagement Service
I/SystemServer( 1276): Text Service Manager Service
I/SystemServer( 1276): NetworkStats Service
I/SystemServer( 1276): NetworkPolicy Service
I/SystemServer( 1276): Wi-Fi P2pService
D/dalvikvm( 1276): GC_CONCURRENT freed 384K, 7% free 7640K/8135K, paused 2ms+3ms
D/WifiHW ( 1276): Unable to unload driver module "wl12xx_sdio": No such file or directory
E/WifiP2pService( 1276): Failed to unload TI driver for P2P
I/SystemServer( 1276): Wi-Fi Service
E/CommandListener( 1167): Failed to open /proc/sys/net/ipv6/conf/wlan0/disable_ipv6: No such file or directory
E/WifiStateMachine( 1276): Failed to disable IPv6: java.lang.IllegalStateException: Unable to communicate to native daemon for disabling ipv6
I/ethernet( 1276): ==>android_net_ethernet_initEthernetNative
I/SystemServer( 1276): Connectivity Service
D/ConnectivityService( 1276): ConnectivityService starting up
E/ConnectivityService( 1276): Ignoring protectedNetwork 10
E/ConnectivityService( 1276): Ignoring protectedNetwork 11
E/ConnectivityService( 1276): Ignoring protectedNetwork 12
D/ConnectivityService( 1276): Starting Ethernet Service.
V/EthernetStateTracker( 1276): Starts...
E/ethernet( 1276): android_net_ethernet_initEthernetNative exited with success
V/EthernetStateTracker( 1276): Successed
I/EthernetService( 1276): Ethernet dev enabled 1
V/EthernetStateTracker( 1276): start to monitor the ethernet devices
I/EthernetManager( 1276): Init Ethernet Manager, service: com.android.server.EthernetService@4114cc40
D/NetworkManagementService( 1276): Registering observer
I/WifiService( 1276): WifiService starting up with Wi-Fi enabled
I/SystemServer( 1276): Throttle Service
I/SystemServer( 1276): Mount Service
D/MountService( 1276): got storage path: /mnt/sdcard description: Internal Storage primary: true removable: false emulated: true mtpReserve: 100 allowMassStorage: fal0
D/MountService( 1276): using emulated external storage
I/SystemServer( 1276): Notification Manager
I/SystemServer( 1276): Device Storage Monitor
I/SystemServer( 1276): Location Manager
I/SystemServer( 1276): Country Detector
I/SystemServer( 1276): Search Service
I/SystemServer( 1276): DropBox Service
I/SystemServer( 1276): Wallpaper Service
D/VoldCmdListener( 1165): volume list
D/MountService( 1276): volume state changed for /mnt/sdcard (mounted -> unmounted)
I/SystemServer( 1276): Audio Service
D/CommandListener( 1167): Setting iface cfg
D/CommandListener( 1167): Trying to bring down wlan0
D/CommandListener( 1167): broadcast flag ignored
D/CommandListener( 1167): multicast flag ignored
E/CommandListener( 1167): Failed to open /proc/sys/net/ipv6/conf/wlan0/use_tempaddr: No such file or directory
D/NetworkManagementService( 1276): rsp <213 00:12:34:56:78:90 0.0.0.0 0 [down broadcast multicast]>
D/NetworkManagementService( 1276): flags <[down broadcast multicast]>
E/WifiStateMachine( 1276): Unable to change interface settings: java.lang.IllegalStateException: Unable to communicate with native daemon to set ipv6privacyextensions}
I/SystemServer( 1276): Dock Observer
W/DockObserver( 1276): This kernel does not have dock station support
I/SystemServer( 1276): Wired Accessory Observer
I/SystemServer( 1276): USB Service
I/SystemServer( 1276): UI Mode Manager Service
I/SystemServer( 1276): Backup Service
V/BackupManagerService( 1276): Initializing package tracking
V/BackupManagerService( 1276): No ancestral data
V/BackupManagerService( 1276): addPackageParticipantsLocked: null
I/BackupManagerService( 1276): New app android never backed up; scheduling
D/dalvikvm( 1276): GC_CONCURRENT freed 291K, 5% free 7867K/8263K, paused 3ms+3ms
I/wpa_supplicant( 1355): rfkill: Cannot open RFKILL control device
E/uim-sysfs( 1166): uim: Un-Installed N_TI_WL Line displine
I/wpa_supplicant( 1355): wpa_driver_nl80211_driver_cmd: Unsupported command BTCOEXSCAN-STOP
E/wpa_supplicant( 1355): Failed to set WoWLAN trigger:-95
I/wpa_supplicant( 1355): wpa_driver_nl80211_driver_cmd: Unsupported command SETBAND 0
I/wpa_supplicant( 1355): wpa_driver_nl80211_driver_cmd: Unsupported command SCAN-ACTIVE
I/wpa_supplicant( 1355): wpa_driver_nl80211_driver_cmd: Unsupported command SCAN-PASSIVE
I/BackupManagerService( 1276): New app com.android.browser never backed up; scheduling
I/BackupManagerService( 1276): New app com.android.calendar never backed up; scheduling
I/BackupManagerService( 1276): New app com.android.inputmethod.latin never backed up; scheduling
I/BackupManagerService( 1276): New app com.android.providers.settings never backed up; scheduling
I/BackupManagerService( 1276): New app com.android.providers.userdictionary never backed up; scheduling
I/BackupManagerService( 1276): New app com.android.sharedstoragebackup never backed up; scheduling
V/BackupManagerService( 1276): Registering transport android/com.android.internal.backup.LocalTransport = com.android.internal.backup.LocalTransport@410f9cf8
V/BackupManagerService( 1276): Starting with transport android/com.android.internal.backup.LocalTransport
V/BackupManagerService( 1276): Google transport not present
I/BackupManagerService( 1276): Found stale backup journal, scheduling
I/BackupManagerService( 1276): android
I/BackupManagerService( 1276): com.android.browser
I/BackupManagerService( 1276): com.android.calendar
I/BackupManagerService( 1276): com.android.inputmethod.latin
I/BackupManagerService( 1276): com.android.providers.settings
I/BackupManagerService( 1276): com.android.providers.userdictionary
I/BackupManagerService( 1276): com.android.sharedstoragebackup
I/BackupManagerService( 1276): Backup enabled => false
I/BackupManagerService( 1276): Opting out of backup
I/SystemServer( 1276): AppWidget Service
I/WindowManager( 1276): SAFE MODE not enabled
D/dalvikvm( 1276): JIT started for system_server
I/SystemServer( 1276): Recognition Service
I/SystemServer( 1276): DiskStats Service
I/SystemServer( 1276): SamplingProfiler Service
I/SystemServer( 1276): NetworkTimeUpdateService
D/PowerManagerService( 1276): system ready!
I/ActivityManager( 1276): System now ready
I/SystemServer( 1276): Making services ready
D/SystemServer( 1276): Starting service: Intent { cmp=com.android.systemui/.SystemUIService }
I/Zygote ( 1276): Process: zygote socket opened
V/TransportControlView( 1276): Create TCV com.android.internal.widget.TransportControlView@41218900
I/ActivityManager( 1276): Start proc com.android.systemui for service com.android.systemui/.SystemUIService: pid=1362 uid=1000 gids={1015, 3002, 3001, 3003}
D/NetworkManagementService( 1276): not enabling bandwidth control
W/NetworkStats( 1276): problem reading network stats: java.lang.IllegalStateException: problem parsing idx 1
I/ActivityManager( 1276): Config changed: {1.0 0mcc0mnc en_US layoutdir=0 sw600dp w1024dp h552dp lrg land finger qwerty/v/v dpad/v s.3}
W/RecognitionManagerService( 1276): no available voice recognition services found
D/dalvikvm( 1276): DexOpt: sleeping on flock(/data/dalvik-cache/system@app@SystemUI.apk@classes.dex)
W/InputManagerService( 1276): Ignoring setImeWindowStatus of uid 1000 token: null
D/dalvikvm( 1276): GC_CONCURRENT freed 201K, 4% free 8217K/8519K, paused 3ms+7ms
D/SystemUIService( 1362): loading: class com.android.systemui.statusbar.tablet.TabletStatusBar
D/SystemUIService( 1362): running: com.android.systemui.statusbar.tablet.TabletStatusBar@410a1bf0
I/wpa_supplicant( 1355): wlan0: SME: Trying to authenticate with d4:4c:24:00:0b:a2 (SSID='BrcmAP0' freq=2412 MHz)
I/ActivityManager( 1276): Start proc jp.co.omronsoft.openwnn for service jp.co.omronsoft.openwnn/.OpenWnnJAJP: pid=1376 uid=10034 gids={}
I/StatusBar.HeightReceiver( 1362): Resizing status bar plugged=false height=48 old=0
W/ThrottleService( 1276): unable to find stats for iface rmnet0
I/ActivityManager( 1276): Start proc com.android.phone for added application com.android.phone: pid=1400 uid=1001 gids={3002, 3001, 3003, 1015}
I/ActivityManager( 1276): START {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher/com.android.launcher2.Launc0
I/ActivityManager( 1276): Start proc com.android.launcher for activity com.android.launcher/com.android.launcher2.Launcher: pid=1415 uid=10010 gids={}
I/SystemServer( 1276): Enabled StrictMode for system server main thread.
W/NetworkManagementSocketTagger( 1276): setKernelCountSet(10010, 1) failed with errno -2
I/wpa_supplicant( 1355): wlan0: Trying to associate with d4:4c:24:00:0b:a2 (SSID='BrcmAP0' freq=2412 MHz)
I/wpa_supplicant( 1355): wlan0: Associated with d4:4c:24:00:0b:a2
I/wpa_supplicant( 1355): wlan0: WPA: Key negotiation completed with d4:4c:24:00:0b:
[ 34.549652] ti_st_open: st_register failed -22
a2 [PTK=CCMP GTK=CCMP]
I/wpa_supplicant( 1355): wlan0: CTRL-EVENT-CONNECTED - Connection to d4:4c:24:00:0b:a2 completed (auth) [id=0 id_str=]
I/ActivityThread( 1400): Pub mms: com.android.providers.telephony.MmsProvider
I/ActivityThread( 1415): Pub com.android.launcher2.settings: com.android.launcher2.LauncherProvider
I/ActivityThread( 1400): Pub sms: com.android.providers.telephony.SmsProvider
D/dalvikvm( 1376): No JNI_OnLoad found in /system/lib/libwnndict.so 0x410812f0, skipping init
I/ActivityThread( 1400): Pub telephony: com.android.providers.telephony.TelephonyProvider
W/TelephonyProvider( 1400): onCreate: confFile=/system/etc/apns-conf.xml oldCheckSum=-1
D/dalvikvm( 1362): GC_CONCURRENT freed 99K, 3% free 6786K/6983K, paused 3ms+16ms
[ 34.656921] (stc): st_register(2)
I/ActivityThrea
[ 34.660430] (stc): chnl_id list empty :2 d( 1400): Pub ic
[ 34.666076] (stk) : st_kim_startc: com.android.p
[ 34.670867] plat_kim_chip_enable
hone.IccProvider
I/ActivityThre[ 34.678131] (stk) :ldisc_install = 1ad( 1400): Pub mms-sms: com.android.providers.telephony.MmsSmsProvider
D/dalvikvm( 1376): GC_CONCURRENT freed 223K, 5% free 6739K/7047K, paused 9ms+1ms
D/dalvikvm( 1276): GREF has increased to 201
D/dalvikvm( 1415): GC_CONCURRENT freed 235K, 5% free 6663K/6983K, paused 2ms+19ms
D/dalvikvm( 1400): GC_CONCURRENT freed 219K, 5% free 6650K/6983K, paused 3ms+49ms
D/dalvikvm( 1376): GC_CONCURRENT freed 356K, 7% free 6918K/7367K, paused 2ms+2ms
I/ActivityManager( 1276): Start proc com.android.smspush for service com.android.smspush/.WapPushManager: pid=1445 uid=10003 gids={}
D/CAT ( 1400): CatService: Is running
D/CAT ( 1400): CatService: NEW sInstance
D/CallManager( 1400): registerPhone(GSM Handler (com.android.internal.telephony.PhoneProxy) {410cc848})
D/dalvikvm( 1362): GC_FOR_ALLOC freed 31K, 2% free 7187K/7303K, paused 155ms
D/dalvikvm( 1376): GC_CONCURRENT freed 369K, 7% free 7033K/7495K, paused 2ms+11ms
I/ActivityManager( 1276): Start proc android.process.acore for content provider com.android.providers.contacts/.CallLogProvider: pid=1463 uid=10007 gids={3003, 1015}
W/ActivityManager( 1276): Unable to start service Intent { act=com.android.ussd.IExtendedNetworkService }: not found
D/dalvikvm( 1276): GC_CONCURRENT freed 181K, 4% free 8476K/8775K, paused 3ms+4ms
I/ActivityThread( 1463): Pub com.android.voicemail: com.android.providers.contacts.VoicemailContentProvider
D/Bluetooth HSHFP( 1400): Starting BluetoothHeadsetService
W/CallNotifier( 1400): Got onMwiChanged() on non-voice-capable device! Ignoring...
I/ActivityThread( 1463): Pub com.android.social: com.android.providers.contacts.SocialProvider
I/ActivityThread( 1463): Pub applications: com.android.providers.applications.ApplicationsProvider
I/StatusBarManagerService( 1276): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@41296f90
I/TabletStatusBar( 1362): DISABLE_CLOCK: yes
D/SystemUIService( 1362): loading: class com.android.systemui.power.PowerUI
D/SystemUIService( 1362): running: com.android.systemui.power.PowerUI@4119e0a0
I/ActivityThread( 1463): Pub contacts;com.android.contacts: com.android.providers.contacts.ContactsProvider2
D/dalvikvm( 1362): GC_CONCURRENT freed 71K, 3% free 7584K/7751K, paused 3ms+3ms
I/SearchManagerService( 1276): Building list of searchable activities
I/StatusBar.HeightReceiver( 1362): Resizing status bar plugged=false height=48 old=48
D/dalvikvm( 1463): GC_CONCURRENT freed 334K, 6% free 6640K/7047K, paused 3ms+9ms
D/dalvikvm( 1415): GC_CONCURRENT freed 210K, 5% free 6962K/7303K, paused 2ms+3ms
D/WifiService( 1276): New client listening to asynchronous messages
I/ActivityThread( 1463): Pub call_log: com.android.providers.contacts.CallLogProvider
I/ActivityThread( 1463): Pub user_dictionary: com.android.providers.userdictionary.UserDictionaryProvider
D/dalvikvm( 1276): GC_CONCURRENT freed 360K, 6% free 8610K/9095K, paused 3ms+14ms
D/dalvikvm( 1415): GC_FOR_ALLOC freed 172K, 5% free 7121K/7431K, paused 56ms
D/dalvikvm( 1415): GC_FOR_ALLOC freed 11K, 5% free 7260K/7623K, paused 30ms
D/dalvikvm( 1415): GC_FOR_ALLOC freed <1K, 6% free 7411K/7815K, paused 55ms
D/dalvikvm( 1362): GC_FOR_ALLOC freed 52K, 3% free 7628K/7815K, paused 53ms
I/ActivityManager( 1276): Displayed com.android.launcher/com.android.launcher2.Launcher: +3s675ms
I/dalvikvm-heap( 1362): Grow heap (frag case) to 17.833MB for 10813456-byte allocation
I/bluedroid( 1276): bt_enable: ret: -1, errno: 5
D/dalvikvm( 1362): GC_CONCURRENT freed 10K, 2% free 18178K/18439K, paused 3ms+29ms
V/OtaStartupReceiver( 1400): onReceive: intent action=android.intent.action.BOOT_COMPLETED mOtaspMode=-1
D/OtaStartupReceiver( 1400): OTASP not supported, nothing to do.
D/PowerManagerService( 1276): bootCompleted
V/DevicePolicyManagerService( 1276): Sending password expiration notifications for action android.intent.action.BOOT_COMPLETED
D/VoldCmdListener( 1165): volume mount /mnt/sdcard
I/Vold ( 1165): /dev/block/vold/179:3 being considered for volume sdcard
D/Vold ( 1165): Volume sdcard state changing 1 (Idle-Unmounted) -> 3 (Checking)
W/logwrapper( 1496): Unable to background process (No such file or directory)
D/MountService( 1276): volume state changed for /mnt/sdcard (unmounted -> checking)
D/MountService( 1276): sendStorageIntent Intent { act=android.intent.action.MEDIA_CHECKING dat=file:///mnt/sdcard (has extras) }
I//system/bin/fsck_msdos( 1165): ** /dev/block/vold/179:3
I//system/bin/fsck_msdos( 1165): ** Phase 1 - Read and Compare FATs
I//system/bin/fsck_msdos( 1165): Attempting to allocate 1816 KB for FAT
I/ActivityManager( 1276): Start proc com.android.contacts for broadcast com.android.contacts/.calllog.CallLogReceiver: pid=1503 uid=10007 gids={3003, 1015}
V/WiredAccessoryObserver( 1276): init()
W/WiredAccessoryObserver( 1276): This kernel does not have wired headset support
