Hi all
I am currently developing software for a board with a C6678 and 2GB DDR3 memory, using SYS/BIOS 6.34.04.22.
I'm using my own platform-file, where I have defined a memory segement "DDR3" of length 0x5c000000 at 0x84000000.
In my .cfg-file, I have created a heapMem instance of size 0x30000000 in section ".data_heap_sec" in that segment, and I have also set that instance to be the BIOS heap my stating: Memory.defaultHeapInstance = Program.gloabl.data_heap in the cfg-file.
Compiling and linking is fine, but looking in the map-file, it seems that my section ".data_heap_sec" is located at 0x84000000 (ok) but only of size 0x10000000 (not ok), and that the .text section follows directly after at 0x94000000.
However, if I in the code use the HeapMem_getStats, I get that the size is 0x30000000 and that I have almost that size free. Testting to allocate memory reveals that I can allocate 0x10000000 two times, and the second memory chunk is well within the next section (.text) and if I try to write to my allocated memory I the program crashes.
So, to me it seems to be a conflict between the cfg-file and the map-file, and between the map-file and what I get using the code.
Is there any size limitation I have missed regarding BIOS heap?
/OH
