During our implementation of the Backlog Order API, we discovered that if an order contains two items with the same part number, one with a Quote Number and the other without, the result after successfully creating the order using the Order API is two TI Orders. One contains only the item with the Quote Number, and the other contains only the item without the Quote Number.
This is the first time we are using Quote Numbers when creating an order, and this result will cause significant changes to the data structure of our designed system!
Why does the API split the order into two separate orders instead of keeping it as one?
Juilien
Below is the JSON content we sent and received:
JSON Sent to Create Orders:
"order": {
"customerPurchaseOrderNumber": "XXXXXXXXXX",
"checkoutProfileId": " XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX ",
"endCustomerCompanyName": " XXXXXXXXXX ",
"lineItems": [
"customerLineItemNumber": 1,
"tiPartNumber": "TPD1E10B06DPYR",
"customerPartNumber": "P12345",
"customerAnticipatedUnitPrice": 0.025,
"quoteNumber": "",
"customerCurrencyCode": "USD",
"schedules": [
"requestedQuantity": 10000,
"requestedDeliveryDate": "2024-10-31"
"customerLineItemNumber": 2,
"quoteNumber": "26929865",
"schedules": [
"requestedDeliveryDate": "2024-11-30"
JSON Returned 200:
"orders" : [
"orderNumber" : "1072521236",
"orderDate" : "2024-07-31",
"customerPurchaseOrderNumber" : " XXXXXXXXXX ",
"orderStatus" : "BEING PROCESSED",
"endCustomerCompanyName" : " XXXXXXXXXX,
"customerPurchaseOrderDate" : "2024-08-01",
"lineItems" : [
"tiLineItemNumber" : "000010",
"tiPartNumber" : "TPD1E10B06DPYR",
"customerLineItemNumber" : "1",
"customerPartNumber" : "P12345",
"itemCheckoutProfileId" : "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX",
"status" : "Not Delivered",
"tiTotalOrderItemQuantity" : 10000,
"customerAnticipatedUnitPrice" : 0.025,
"customerCurrencyCode" : "USD",
"tiUnitPrice" : 0.00,
"tiCurrencyCode" : "USD",
"messages" : [
"code" : "TI-TXT-005",
"type" : "INFO",
"reason" : "Pricing could not be determined",
"message" : "Sales order created, but price is not set up. For further support, contact TI customer support https://support.ti.com/csm"
"code" : "TI-TXT-006",
"type" : "INFO",
"reason" : "Item is not scheduled and may require manual schedule",
"message" : "Item is pending manual schedule which may take up to 48 hours. If your item is not scheduled after 48 hours, please contact TI customer support https://support.ti.com/csm"
"schedules" : [
"requestedQuantity" : 10000,
"requestedDeliveryDate" : "2024-10-31"
"orderNumber" : "1072521237",
"endCustomerCompanyName" : " XXXXXXXXXX ",
"lineItems" : [
"customerLineItemNumber" : "2",
"itemCheckoutProfileId" : " XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX ",
"quoteNumber" : "26929865",
"tiUnitPrice" : 0.025,
"messages" : [
"type" : "INFO",
"schedules" : [
"requestedDeliveryDate" : "2024-11-30"
"termsOfSale" : "Sale of TI products by TI are subject to TI's Terms of sale ">www.ti.com/.../terms-of-sale.html"
