TI-API: TI-API
Part Number: TI-API
I´m trying to set up so I can buy from you directly. TI store order API´s. But now I wonder if I need an ERP system to do the last set up
I have got API Keys and access
Teledyne SP Devices AB
Request API
Request API keys and access.
20 Feb 2024 by Anna Nätell
  • You do not need an ERP system, but you do need a way to receive the Json payload responses from your API create calls to receive information back about the order you are placing and if you want to get shipment and invoice information- also a way to retrieve a Json payload or receive a push response.
    API endpoints are needed on your end for connecting with our APIs.
     You have prerequisites that are required like myTI account once approved and setup receive your credentials then you can order from the store once you are setup and use the myTI dashboard - peruse through the getting started documentation link and it may then make a little more since to you - TI store API suite - Getting started | TI API Portal
