LMH0324: Use of a balun at the input
Part Number: LMH0324
Other Parts Discussed in Thread: LMH0318
I must isolate the SDI signal on the PCB board. So my idea was to use a balun at the input. It should transform the unbalanced Signal from the BNC connector to an balanced signal, which I would connect to the IN+ and IN- of the LMH0324. Is this working? The datasheet only shows the use as an unbalanced input!
Vice versa, I also need to this on the output side with the LMH0318.
thanks and greetings
Matthias
  • Hi Matthias,
    Please note LMH0324 and LMH0318 are mainly used and characterized for SDI market where these devices used in a single ended fashion. For isolation purpose, perhaps one to one 75-ohm transformer with adequate bandwidth can be used. Please check with Pulse Transformer regarding this component.
    Regards ,, Nasser
