Other Parts Discussed in Thread: ALP, USB2ANY
Hi Team,
If the ALP GUI is not showing the MAP tab, is there a way to get the tab into the profile for the 948?
Thank you,
Jared
Hi Team,
Thank you,
Jared
Hey Jared,
Please download the newest version of the ALP tool from TI.com and also download/install the profile updater tool from the ALP download page. That will give you the latest versions of everything related to 948. Make sure that the 948 has a valid I2C connection to the target (ex. through the EVM or through USB2ANY).
Casey
Hi Casey,
Everything you highlighted above has been done. What would come next?
-Jared
Hey Jared,
Can you send a screen shot of what you are seeing in ALP?
Casey
Jared,
Are you installing ALP in the default folder
C:\Program Files (x86)\Texas Instruments\Analog LaunchPAD v1.57.0010
or some custom folder? We recently found the ALP PROFILE UPDATE (v10) does not install in other folders. Only it installs in the above default folder. The next update (v11) will resolve this.
So could you please check this?
I am guessing this could be the issue because my 948 info tab (with v10 update) looks as below (I don't see Scan Connected Devices in yours)
Vishy
