TPS65987D: PD FW setting for HD3SS460
Part Number: TPS65987D
Other Parts Discussed in Thread: HD3SS460
Hi team,
in the previous E2E post, I ask about how to set GPIO event for HD3SS460.
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1083992/tps65987d-connect-to-hd3ss460
Chris told me I can use these GPIO event for HD3SS460.
Now, my customer board come back and test it, the monitor can't display. so I would like to know does this issue related to PD GPIO event setting?
because my customer follow below reference design to draw the circuit, I think the schematic is good.
https://www.ti.com/lit/an/slla403a/slla403a.pdf?ts=1641490153356&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FTUSB564&_ticdt=MTY1MTc0MjQ1MHwyMTYwMzg3MjB8R0ExLjIuMTkxODc0NDM5OC4xNjQ0MjA2ODUy
for my customer 987DJ schematic,
is any GPIO setting issue in their system? I also find the GPIO 7 also use the port 1 DP mode select event, this is the same as GPIO 21, is it ok with that?
GPIO 18 : port 1 cable orientation event
GPIO 19 : port 1 AMSEL event
GPIO 21 : port 1 DP mode select event
GPIO 7 : port 1 DP mode select event
and I also ask my customer to measure these GPIO.  I don't understand why GPIO 7 and GPIO 21 are different, it doesn't make sense to me, because both are using port 1 DP mode select event.
GPIO\Cable
USB 2.0 to USB-C
UCB-C to UCB-C
GPIO 7-IRQ
L
H
GPIO 18-POL
L
L
GPIO 19-AMSEL
H
H
GPIO 21-EN
L
L
Attached file is schematic, layout and pjt file and CC log.
SRD2_FEBD_4H5HA01S02_20220324-TI.pdf4H5HA01S02_0322.zip20220505_SRD2_987dj_12.12.pjtNo_Picture.tdc
