Part Number: PCA9534A
Other Parts Discussed in Thread: PCA9554A, TCA9534A, TCA9554A, TCA9534
I am using 3x PCA9534A IO expanders and sometimes the device will hold the SDA line low at power up. All that is on the bus is a micro controller and 3x PCA9534As. The micro is modular so I removed that and still see SDA line pulled low during power up. The VCC 3.3V rail looks clean (no glitches) and rises in about 20ms. SDA starts to rise with VCC and once VCC hits about 1V, the SDA line get's pulled low. This happens maybe 30% of the time when I power up. When VCC hits Vpor, the outputs should go to their default state but what about SDA? Is this a know issue with PCA9534A?
I was using the NXP version of PCA9554A w/o this issue, but switched to this part due to supply chain issues. All my IO have external pull downs, so the internal pull ups are not needed.
the pink signal is SDA and blue is VCC. It is 1V/div so SDA actually only gets to about 0.5V
