Other Parts Discussed in Thread: DP83848-EP
Hi Expert:
We are testing DP83848Q-Q1 read PHY identifier register #2 (address 0x03h) = 5c90 , but datasheet show =5Ca2 different with test result.
we check IC top marking is DP83848QSQ that is the DP83848Q-Q1 series PN. after that
we Back to check the register value 5C90 the relative PN is DP83848-EP , not Automotive grade part. I attached the issue slide and the schematic , could you please help check why register value different with the relative PN? thank you.
DP83848Q-Q1 address issue.pdf0827.FOR TI_Roy 100BASETX schematic (002).pdf
