Can you suggest the cable which will be compatible with the receptacle 2302454-9. Or any connection guidelines on how it should be connected.
Can you recommend the crimping part for 2302454-9 which will be compatible with your suggested cable.
- Can you suggest a alternate Receptacle for 9-2304372-9 as manufacturer TE connectivity recommended part (9-2302454-9) is not available.
If needed, suggest a different 2 pin Automotive connector with its receptacle and cable type which will be compatible with our system.
