The output data type can be configured through CSICFG1 register. Can the OFMT be set to any of those values, or is it restricted by the IFMT setting?
Hi Wei,
Please refer to this table in datasheet.
This table means that you could configure IFMT to what format type of input depending on the coming video stream, and you could adjust it to the display screen interface by configuring OFMT. Note - Color space conversion is only available from RGB to YUV.
Fadi A.
Hi Fadi,
Thank you. Do you know if similar settings also available for ds90ur910?
Wei,
910 only supports RGB888 as mentioned in the datasheet
Casey
