The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TCA8418: How to configure TCA8418 IC to save only "Pressed" events in the FIFO?
Part Number: TCA8418
The TCA8418 key scanner IC, contains a FIFO which stores both "Pressed" and "Released" events. I want to configure it to save only the "Pressed" events. How can I do it and what are the register addresses and the values that I should set?
