SN65ALS176: Can SN65ALS176 support 1000m transmission?
Part Number: SN65ALS176
Other Parts Discussed in Thread: THVD1500
Hi team,
Could you please kindly help check if our SN65ALS176 can support 1000m transmission with 115kbps?
Brian
  • This depends mainly not on the transmitter, but on how much jitter is added by the cable.
    115 kbps at 1000 m should work:
    (And the SN65ALS176 is quite old. The THVD1500 is a P2P replacement that is more modern, more robust, cheaper, and uses less power.)
