Other Parts Discussed in Thread: ESD2CANFD24,
Hi team,
Customer has several questions that I need to check.
- Customer use Star topology in their system and get problems to improve the signal quality, remove the ringing. For example, with different data rate from 1M to 5M, is there a recommend sample point in percentage? Do we have document for reference? Can this problem solved by software?
- Now they use hand-in-hand connection with 5M, Do we have recommend configuration for this?
- Customer use ESD2CANFD24 on each node, there are 10*Nodes totally for the transceiver, so 10 ESD Diode on CANH or CANL, it will introduce much parasitic capacitance, will it reduce the signal quality? If so how to solve it?
Thanks a lot
Matthew
