Other Parts Discussed in Thread: DS90CF383B
Does the DS90C383B support 18 - bit cllor host signal input to 24 - bit color lcd Panel Display Application,how to set the pins?
Hi c h,
Could you clarify your question? If I understand your question correctly, the customer wants to use the DS90C383B with 18-bit color (6-bit RGB)? Why it is trying to apply 18-bit even though host signal input is 24-bit?
Josh
the team is out due to the Holidays. Responses will be delayed from Dec. 24 through Jan. 2.
Thank you for your patience
Hi c h,
Yes the DS90CF383B can be used in 18 bit RBG to LVDS application. They will need to remap the RGB[7:0] MSB bits to RGB[5:0] and drop the LSB bits. Please see the following Application Note for more details (follow the pin formatting for "C385"): http://www.ti.com/lit/an/snla014/snla014.pdf
Josh
