DS90UB914A-Q1: Power supply pins capacitors
Part Number: DS90UB914A-Q1
Hi All,
I have a question about the DS90UB914A.
(1) The data sheet recommends 0.01uF, 0.1uF, and 22uF capacitors for VDDCML0/1, but the EVM uses 0.1uF, 1uF, and 22uF.
Which recommendation should I follow?
(2) The data sheet recommends 0.01uF and 0.1uF capacitors for VDDR and VDDD, but the EVM uses 0.1uF and 1uF.
(3) The data sheet recommends 0.01uF and 0.1uF capacitors for VDDSSG, but the EVM uses 0.1uF and 1uF, and it is isolated from other power supplies by a 0Ω resistor.
The EVM seems to have a better bypass effect, so which recommendation should I follow?
(4) Regarding the VDDPLL capacitors, the data sheet recommends 0.01uF and 0.1uF, but the EVM uses 0.1uF and 1uF.
Which is better to follow?
(5) Regarding the VDDIO1, 2, and 3 capacitors, the data sheet recommends 0.01uF, 0.1uF, and 4.7uF, but the EVM uses 0.1uF, 1uF, and 22uF.
Ishiwata
