TCA9517: What is the value of the internal pull-up resistor on the EN pin of TCA9517?
Part Number: TCA9517
We want to add a pull - down resistor to the EN pin of TCA9517 so that it defaults to low level after power - up, and we can pull it high via MCU when needed. However, the datasheet states that there is an internal pull - up resistor on the EN pin. Could you please tell us what the resistance value of this internal pull - up resistor is? This way, we can select an appropriate resistance value for the pull - down resistor. Thank you.
