Other Parts Discussed in Thread: TPD2EUSB30A, TPD2E001, TPD2E2U06, TPD4E05U06, TPD4E001, TPD4E1U06
I want to design this into a system where the eternal sensors are running on 5V. I notice that your operating voltage I/O is stated to be 5V but that your absolute maximum operating VCC is rated at 5V?! No 5V supplies in this system are perfect as they will be a little higher or lower. Also I am sure the external sensor inputs could be anywhere from 4.75 to 5.25 at least. Is this doable or should I forget this part? Do you have a similar part like this that can handle 5V plus or minus some tolerance?
