Can you explain what does "Signal detect assert level for active data signal" ?
Is this the minimum voltage required at component inputs for understanding a logical level ? If not, what is this minimum voltage ?
Best regards
Christian
Best regards
Christian
Hi Christian,
The Signal Detect Assert level = The minimum amplitude required for the device to declare that there is an active signal on the inputs.
The minimum voltages are given in the datasheet in Table 6 on page 14 of the datasheet.
If the signal amplitude on the device high speed input falls below the "de-assert" level the signal detect will declare "no signal present" on the input. This will result in a muted output with 0V differential amplitude.
Lee
