Part Number: DS90UB953A-Q1
Team,
We are using the DS90UB953ATRHBTQ1 for our serializer. We are running it with a MIPI camera, 2-lane CSI-2 at 1080p, 30 fps. We’re mostly interested in the following for this part:
- Additional guidance on how to set the clock rate to ensure the FPD-Link rate is minimized but still meets the > CSI-2 bandwidth requirement for the FPD link to operate.
- How to configure it for synchronous mode with a 24 MHz clock generated from the de-serializer part. Our camera appears to require a 24 MHz clock to run at 1080p, 30fps. We think the MIPI bandwidth will be <800 mbps per lane, but the camera datasheet lacks any information on the MIPI data rates. Any advice or guidance you have regarding the clocking and MIPI rate would be extremely helpful.
- Guidance on how to configure the outputs for differential, STP style transmission and any layout guidelines regarding differential signal use of the FPD link. The datasheet and evaluation modules talk mostly about the use of a coaxial cable. We would want to run differential signals across a series of rigid-flex-rigid PCBs to get our signals back to the de-serializer.
Thank you.
