From the datasheet of TPD12S016, I found that it's interfaced with standard HDMI connector. Can I use it with a micro-coaxial connector insted of using standard HDMI connector?
I've assigned this issue to the relevant expert who will get back to you shortly.
Thank you,
Hari
HI,
This device is design for HDMI connector application, I don't know your micro-coaxial connector pin, if you target for the ESD protection it may meet but you need to consider the voltage in other function pin such as CEC, I2C ..
Hi Michael
Thanks for the reply,
I am using USL00-30L mico-coaxial connector I want to use TPD12S016 for ESD protection.
