CLC001: Generate and transmit CLOCK and SYNC signals over 20 meters of CAT5 twisted pair cable
Part Number: CLC001
Greetings to all from Spain,
I need to design a 4-port "hub" to generate a CLOCK signal (38.4 MHz) and a SYNC signal, for the distribution of those signals to 4 devices, via CAT5 twisted pair cable, at a distance of between 10 and 20 meters.
I have no experience in designing this type of circuit. Could you help me with the selection of ICs for the different circuit blocks of this "hub", and also in the signal recovery block in the receiving devices?
Thank you for your attention and help.
Regards.
