Could you help me confirm on the below questions, thanks in advance.
1. We recommend connect the bigger loss at the channel B side as the B side have the 24dB CTLE, am I right?
2. I have checked the positive and negative trace for one lane looks the same, may we swap the outside connection for easy layout? Like I connect outside Negative trace to device positive pin, connect positive trace to device negative pin? is this acceptable?
Thanks.
