Other Parts Discussed in Thread: TPD4E05U06, TPD4E1U06
Team,
I have a customer that has commented that they typically do not connect the Vcc side because in my experience, it can direct ESD discharge current into the supply rail, and can disrupt a uC. This also state that this is more likely when the product does not have a chassis or frame, per se, for the ground side, correct. Do we have any comment as to our recommendations on whether or not TVS should be applied to the Vcc side of the circuit?
For the TVS array, I usually do not connect the Vcc side because in my experience, it can direct ESD discharge current into the supply rail, and
can disrupt a uC. This is more likely when the product does not have a chassis or frame, per se, for the ground side. Just wondering what your experience has been with other customer usage. I’ve designed many products with similar devices and always left the Vcc unconnected successfully.
