Hi , we are using the two-chip solution of TFP401 and SN75LVDS83B to convert DVI input to LVDS output. we also get color issue as "DVI to LVDS, Bad colors on output video". We have done follow test.
1 We found true green can't be displayed,there are black if we input true green .All the TFP401 green output is low level.
2 If we exchange DVI input wire, DVI-TMDS0,& TMDS1, if we input true red, then LCD display true green,
3 We use display test software, the display gradient can't work right,Perhaps some color has problem.
4 We change EDID to change display frequency, there are no influence.
5 Our design follows SLLA325A,(HDMI/DVI to LVDS Bridge).
6 We will try to display all the color to check every RGB output
Can you give us some advice? Does the EDID will influence the result?
