Other Parts Discussed in Thread: TLC7524, LM339
Hello everybody,
Thanks a lot for your attention to my question about the use of the component TLC7524.
Generally I use it for my design of the controler of stepper motor.
The dac is used to translate the datas digital to analog. And the
signal analog is connected to the comparator LM339 as the pole positif.
this photo shows my datas digital hex. it varies from 0x03 to 0xFE
This photo shows the datas analogic.But in this photo it can't precisely show what i want.Then i turn to look what's going on at the voltage reference.
H
In this photo you see my voltage reference. It should be constant but it's not. I think here is the reason why i can't get a correct result.
This photo is my connection the the component. I used the mode voltage. I've tried to pose a cap between OUT1 and gnd, but it doesn't work. then I put a cap between REF and gnd, it doesn't work neither.
Anyone can tell me why? what should i do to relove it? Thank you very much for your help.
Best regards.
Yiqing
