Do TI have a device similar to the DP159 that supports Displayport 1.2?
Meir.
Meir.
Hi Meir,
If you are looking for a DisplayPort 1.2 retimer, DP159 can do the job.
Follow the application note DP159 as DisplayPort Retimer
Hi Meir,
The customer would use this device as DP retimer, it doesn't deal with HDCP data
When HDCP is used, keys are shared through DDC which DP159 monitors in DP++ to HDMI mode.
So, in retimer mode, there is a direct connection between sink and source, DP159 is not involved, if both sink and source support HDCP the application should work fine.
