Part Number: DS90UR916Q-Q1
Dear all:
Our customer want to used DS90UR916 connect DS90UR241, but not RGB output. Please help check any config that we must do on 916 or 241? if have any thing missed? thanks!
Test condition:
1. We set CONFIG[1:0] to 10 with HW or I2C test waveform.docx , but DS90UR241 LOCK always pull low(PLL Unlocked), attached is waveform,please help to check is it ok for the sequence?
2. We used DS90UR905 connect to DS90UR916, RGB output abnormal. LOCK=1 PLL is locked.
3. We uesd DS90UR124 connect to DS90UR241, RGB output abnormal. LOCK=1 PLL is locked.2260.test waveform.docx5488.DS90UR916 Circuit.docx
In reply to Junqiang Shi:
Dear Steven:
1. ur241 lock always is pulled to low? UR241 is serializer, and has no lock pin?
It's my mistake, DS90UR916 LOCK=0
2. We design two boards( DS90UR905 and DS90UR241), connect UR905, UR916 board LOCK=1 and we can test the waveform on R.G.B PIN. but conect UR241,UR 916 LOCK=0 and no waveform output ON R.G.B PIN.
3. We set CONFIG[1:0] to H:L , but LOCK=0. I want to know any other set that we must do? if not other set need to do, It maybe cause by Setup failure? we attached PDB and CONFIG 1 waveform for your reference.
In reply to user3830479:
