I searched for available Ethernet PHY and magnetic at operating temperatures of -55 to 125 and did found the DP83848M.
And i checked the magnetics requirements for the DP83848 family of devices in the Design & Layout Guide: www.ti.com/.../snla079d.pdf .
However I wish to use the Pulse 100B-1003X magnetics which is suitable to a broader range of temperatures.
There is a difference in the signal loss rate(insertion loss, return loss, etc) between the magnetics required by the DP83848M and the magnetics I want to use.
If I connect the DP83848M to the 100B-1003X, will there be a problem sending or receiving data?
Thanks.
