Hello Team,
Please tell me the forward voltage of the diode circled below.
Kato
Hello Team,
Kato
Hi Kato,
This is the parameter V_F (clamp forward voltage) in the datasheet. For this device, it is 1.7V (typ) and 2.1V (max).
Alek Kaknevicius
Hi Kato,
You are right, and thank you for catching this. VF is referring to the flyback diode, not the output clamping diode. While 0.7V is a very ideal voltage for a diode, many different types of diodes can be created, and these will result in different voltage drops. As you mentioned, it would be possible to also string diodes in series to increase the forward voltage.
As for the forward voltage of the output clamping diode, we did not take this data when characterizing the device. With the emitter (pin E) pulled to ground, the diode should not be forward biased since the output would have to be very negative. Could you help me understand why this information is needed?
Alek Kaknevicius
