Other Parts Discussed in Thread: LMH0384
I understand the normal application uses an SDI equalizer (e.g. LMH0384) before the SDI deserializer (LMH0341). Is this absolutely required? I my application, there is about 1 foot of coax from the SDI output to my input. In this case, can we avoid the equalize chip???
If so, how should the 75 ohm SDI coax be attached to the LMH0341 deserializer differential input? I had expected this would be a common question, but did not find any info in the datasheets or forum posts. (Maybe I'm missing something, sorry). Can we hook up the LMH0341 to SDI coax with the same circuit as is used with the equalizer? For example, would this work?
Thank you for considering my question!
Ryan
