Hi Sir,
if want to modify PID/VID and product string by external EERROM, how to write?
Just like page13 in DS, right? but can't see "product string".
thanks~
Driscoll
Hi Sir,
thanks~
Driscoll
Hi Sir,
thanks for your check.
I got PCBA today, but test fail at "USB IF chapter 9" (we had compared with other hub and with same downstream device-- mouse).
After test item "L1Suspend/Resume Test", the communication will break, then the signal is suspend and resume.
Could you help check what happen?
PS: if close "remote wake function" of mouse, the test will PASS
thanks~
<HTML><HEAD> <META http-equiv="X-UA-Compatible" content="IE=edge" /> <META charset="UTF-8" /> <STYLE type='text/css'> BODY { background-color: #DFDFDF; } .dm_display { color: Navy; font-family: monospace; background-color: White; border-width: 3px; border-style: outset; } #suite-output { background-color: #FFFFDD; border: ridge 3px #FFFFDD; border-collapse: collapse; padding: 0; margin: 0; empty-cells: hide } #test-header { font-weight: bold; font-size: large; border-top: ridge 2px #FFFFDD; border-bottom: ridge 2px #FFFFDD; padding: 0; margin: 0; } .test-pass, .test-fail { float: right; border-left: ridge 2px #FFFDD; width: 6em; } .test-pass { background-color: #00FF00; } .test-fail { background-color: #FF8888; } .test-details { clear: both; font-family: monospace; padding: 0; margin: 0; empty-cells: hide; } .label { float: left; width: 6em; } .content { white-space: pre-wrap; margin-left: 6em; } .err_log, .warn_log { color: Red; } .err_log { font-weight: bold; } </STYLE> <TITLE>Chapter 9 Tests - USB 2 - 2018-10-12 11-22-59</TITLE> <META name='Suite-Name' content='Chapter 9 Tests [USB 2 devices].cvtests' /> <META name='Suite-Revision' content='7811' /> <META name='Suite-Revision-Date' content='2015-03-02 10:30:49 -0800 (Mon, 02 Mar 2015)' /> <META name='Test-Version' content='CVExe.exe ver 2.6.1.0' /> <META name='Test-Version' content='CommonToCVAndCVSettings.dll ver 2.6.1.0' /> <META name='Test-Version' content='CommandVerifierLog.dll ver 2.6.1.0' /> <META name='Test-Version' content='TSMFCGuiDialogHelperDLL.dll ver 2.6.1.0' /> <META name='Test-Version' content='TestUtilities.dll ver 2.6.1.0' /> <META name='Test-Version' content='TestSuiteEngine.dll ver 2.6.1.0' /> <META name='Test-Version' content='xhci_DevIOCTL.dll ver 2.1.4.0' /> <META name='Test-Version' content='xhci_TestServices.dll ver 2.1.4.0' /> <META name='Test-Version' content='USBUtilities.dll ver 1.4.5.1' /> <META name='Test-Version' content='StackSwitcher.dll ver 1.4.5.1' /> <META name='Test-Version' content='xhci_USBCommandVerifier.dll ver 2.1.4.0' /> <META name='Test-Version' content='USB20_USBCommandVerifier.dll ver 2.1.4.0' /> <META name='Host-Controller' content='VID=1033,PID=0194' /> <META name='Device-Under-Test' content='VID=03F0,PID=4B4A' /> <META name='Device-Speed' content='Full Speed' /> <META name='Topology' content='XHCI HC -- FS Hub -- DUT' /> <META name='Test-Pass' content='TD 9.1 - Device Descriptor Test (Configuration Index 0) - default [Fails (0); Aborts (0); Warnings (2)]' /> <META name='Test-Pass' content='TD 9.2 - Configuration Descriptor Test (Configuration Index 0) - default [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.3 Interface Association Descriptor Test (Config 0) [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.4 - Interface Descriptor Test (Configuration Index 0) - default [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.5 - Endpoint Descriptor Test (Configuration Index 0) - default [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.7 - BOS Descriptor Test - Device State Default [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.1 - Device Descriptor Test (Configuration Index 0) - addressed [Fails (0); Aborts (0); Warnings (2)]' /> <META name='Test-Pass' content='TD 9.2 - Configuration Descriptor Test (Configuration Index 0) - addressed [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.3 Interface Association Descriptor Test (Config 0) [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.4 - Interface Descriptor Test (Configuration Index 0) - addressed [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.5 - Endpoint Descriptor Test (Configuration Index 0) - addressed [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.7 - BOS Descriptor Test - Device State Addressed [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.1 - Device Descriptor Test (Configuration Index 0) - configured [Fails (0); Aborts (0); Warnings (2)]' /> <META name='Test-Pass' content='TD 9.2 - Configuration Descriptor Test (Configuration Index 0) - configured [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.3 Interface Association Descriptor Test (Config 0) [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.4 - Interface Descriptor Test (Configuration Index 0) - configured [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.5 - Endpoint Descriptor Test (Configuration Index 0) - configured [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.7 - BOS Descriptor Test (Configuration Index 0) - Device State Configured [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.9 - Halt Endpoint Test (Configuration Index 0) [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.13 - SetConfiguration Test (Configuration Index 0) [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.14 - Suspend/Resume Test (Configuration Index 0) [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.12 - Remote Wakeup Test (Configuration Index 0) - Enabled: [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='TD 9.12 - Remote Wakeup Test (Configuration Index 0) - Disabled: [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Pass' content='L1Suspend/Resume Test (Configuration Index 0) [Fails (0); Aborts (0); Warnings (0)]' /> <META name='Test-Fail' content='TD 9.16 - Enumeration Test (repeat 150 times) [Fails (1); Aborts (1); Warnings (0)]' /> <META name='Suite-Result' content='FAIL [Fails (1); Aborts (2); Warnings (6)]' /> <META name='Log-Name' content='Chapter 9 Tests - USB 2 - 2018-10-12 11-22-59.html' /> <META name='Test-Count' content='25' /> </HEAD> <BODY><DIV id='suite-summary'> <STRONG>TEST SUITE: </STRONG> Chapter 9 Tests [USB 2 devices].cvtests<BR> <STRONG>REVISION: </STRONG> 7811<BR> <STRONG>REVISION DATE: </STRONG> 2015-03-02 10:30:49 -0800 (Mon, 02 Mar 2015)<BR> <STRONG>OPERATING SYSTEM: </STRONG> Windows 10 Pro (Build 17134.1.amd64fre.rs4_release.180410-1804)<BR> <STRONG>WORKSTATION: </STRONG> <BR> <STRONG>DATE: </STRONG> Friday, October 12, 2018<BR> <STRONG>TIME: </STRONG> 11:23:51 AM<BR> <STRONG>OPERATOR: </STRONG> test<BR> <STRONG>NUMBER OF TESTS: </STRONG> 25<BR> <STRONG>LOG NAME: </STRONG> Chapter 9 Tests - USB 2 - 2018-10-12 11-22-59<BR> <STRONG>RESULT: </STRONG> <A href='#anchor_28'>failed</A><BR> <HR> </DIV> <BR><BR> <DIV id='suite-output'> <DIV id='test-header'>Initialize Test Suite</DIV> <DIV class='test-details'> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Test log initialized.</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Log Level: Normal</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>User Input module initialized</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Windows 10 Pro (Build 17134.1.amd64fre.rs4_release.180410-1804)</DIV></DIV> <DIV style='color:#00005F'><DIV class='label'>INFO</DIV><DIV class='content'>CVExe.exe ver 2.6.1.0</DIV></DIV> <DIV style='color:#00005F'><DIV class='label'>INFO</DIV><DIV class='content'>CommonToCVAndCVSettings.dll ver 2.6.1.0</DIV></DIV> <DIV style='color:#00005F'><DIV class='label'>INFO</DIV><DIV class='content'>CommandVerifierLog.dll ver 2.6.1.0</DIV></DIV> <DIV style='color:#00005F'><DIV class='label'>INFO</DIV><DIV class='content'>TSMFCGuiDialogHelperDLL.dll ver 2.6.1.0</DIV></DIV> <DIV style='color:#00005F'><DIV class='label'>INFO</DIV><DIV class='content'>TestUtilities.dll ver 2.6.1.0</DIV></DIV> <DIV style='color:#00005F'><DIV class='label'>INFO</DIV><DIV class='content'>TestSuiteEngine.dll ver 2.6.1.0</DIV></DIV> <DIV style='color:#00005F'><DIV class='label'>INFO</DIV><DIV class='content'>xhci_DevIOCTL.dll ver 2.1.4.0</DIV></DIV> <DIV style='color:#00005F'><DIV class='label'>INFO</DIV><DIV class='content'>xhci_TestServices.dll ver 2.1.4.0</DIV></DIV> <DIV style='color:#00005F'><DIV class='label'>INFO</DIV><DIV class='content'>USBUtilities.dll ver 1.4.5.1</DIV></DIV> <DIV style='color:#00005F'><DIV class='label'>INFO</DIV><DIV class='content'>StackSwitcher.dll ver 1.4.5.1</DIV></DIV> <DIV style='color:#00005F'><DIV class='label'>INFO</DIV><DIV class='content'>xhci_USBCommandVerifier.dll ver 2.1.4.0</DIV></DIV> <DIV style='color:#00005F'><DIV class='label'>INFO</DIV><DIV class='content'>USB20_USBCommandVerifier.dll ver 2.1.4.0</DIV></DIV> <DIV style='font-weight: bold;color:#00007F'><DIV class='label'>INFO</DIV><DIV class='content'>Host selected: xHCI Host: VID=0x1033, PID=0x0194 (PCI bus 2, device 0, function 0)</DIV></DIV> <DIV style='font-weight: bold;color:#00007F'><DIV class='label'>INFO</DIV><DIV class='content'>DUT selected: FS Device (HID) addr=2: VID=03f0, PID=4b4a</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Topology: XHCI HC -- FS Hub -- DUT</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Full Speed Device.</DIV></DIV> </DIV> <DIV id='test-header'>Get Number Of Configurations</DIV> <DIV class='test-details'> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>USB Version number of device: 2.00</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of configurations: 1</DIV></DIV> </DIV> <DIV id='test-header'>Get Number Of Configurations - Other Speed</DIV> <DIV class='test-details'> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of Other Speed configurations: 0</DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_4'>TD 9.1 - Device Descriptor Test (Configuration Index 0) - default</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:07 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device descriptor length : 0x12</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device descriptor type : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Major version : 0x2</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Minor version : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Each interface specifies its own device class type</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device sub class : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device protocol : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device MaxPacketSize0 : 0x40</DIV></DIV> <DIV class='warn_log'><DIV class='label'>WARNING</DIV><DIV class='content'>Could not open file 'usb.if'.</DIV></DIV> <DIV class='warn_log'><DIV class='label'>WARNING</DIV><DIV class='content'>Failed to get vendor information for VendorID : 0x3F0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device ProductID : 0x4B4A</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device BCD : 0x15</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>ENGLISH_US language string descriptor is : HP</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>ENGLISH_US language string descriptor is : HP USB Fingerprint Mouse</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>ENGLISH_US language string descriptor is : 110103085405161C</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of configurations device supports : 0x1</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:08 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.1 - Device Descriptor Test (Configuration Index 0) - default: Number of: Fails (0); Aborts (0); Warnings (2) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_5'>TD 9.2 - Configuration Descriptor Test (Configuration Index 0) - default</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:08 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor contains descriptor of type : 0x4 (Interface Descriptor)</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor contains descriptor of type : 0x21 (HID Descriptor)</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor contains descriptor of type : 0x5 (Endpoint Descriptor)</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of interface descriptors found 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of alternate interface descriptors found : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of endpoint descriptors found : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor length : 0x9</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor type : 0x2</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor TotalLength : 0x22</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor NumInterfaces : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor ConfigurationValue: 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor string descriptor index : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor bmAttributes : 0xA0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device supports remote wake up</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>MaxPower = 50 PowerMultiplier = 2</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Maximum power device requires : 100mA</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device is BUS POWERED</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:09 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.2 - Configuration Descriptor Test (Configuration Index 0) - default: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_6'>TD 9.3 Interface Association Descriptor Test (Config 0)</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:09 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'> Device has 1 function, of which 0 have an Interface Association descriptor.</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Function #1 does not have an Interface Association Descriptor.</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'></DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>This device does not contain an Interface Association Descriptor</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:10 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.3 Interface Association Descriptor Test (Config 0): Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_7'>TD 9.4 - Interface Descriptor Test (Configuration Index 0) - default</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:11 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Bandwidth check passed</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Testing Interface number : 0x0 Alternate setting : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor length : 0x9</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bDescriptorType : 0x4</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bAlternateSetting : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bNumEndPoints: 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bInterfaceClass reserved for assignment by the USB-IF : 0x3</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface class code indicates [HID] Interface</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface sub class : 1 <not defined></DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface protocol : 2 <not defined></DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bInterfaceSubClass : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bInterfaceProtocol assigned by the USB-IF : 0x2</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor iInterface : 0x0</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:12 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.4 - Interface Descriptor Test (Configuration Index 0) - default: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_8'>TD 9.5 - Endpoint Descriptor Test (Configuration Index 0) - default</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:12 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'> Testing Interface number : 0x0 Alternate setting : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor length : 0x7</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor type : 0x5</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint Type : Interrupt, Number : 0x1, Direction : IN</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor bmAttributes : 0x3</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor raw MaxPacketSize : 0x8</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor interval : 0x8</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:13 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.5 - Endpoint Descriptor Test (Configuration Index 0) - default: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_9'>TD 9.7 - BOS Descriptor Test - Device State Default</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:13 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration Index 0x00 has a Configuration Value of 1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>USB Version number of device: 2.00</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device supports version of the USB Protocol that does not support BOS Descriptor</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:14 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.7 - BOS Descriptor Test - Device State Default: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_10'>TD 9.1 - Device Descriptor Test (Configuration Index 0) - addressed</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:14 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device descriptor length : 0x12</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device descriptor type : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Major version : 0x2</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Minor version : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Each interface specifies its own device class type</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device sub class : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device protocol : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device MaxPacketSize0 : 0x40</DIV></DIV> <DIV class='warn_log'><DIV class='label'>WARNING</DIV><DIV class='content'>Could not open file 'usb.if'.</DIV></DIV> <DIV class='warn_log'><DIV class='label'>WARNING</DIV><DIV class='content'>Failed to get vendor information for VendorID : 0x3F0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device ProductID : 0x4B4A</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device BCD : 0x15</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>ENGLISH_US language string descriptor is : HP</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>ENGLISH_US language string descriptor is : HP USB Fingerprint Mouse</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>ENGLISH_US language string descriptor is : 110103085405161C</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of configurations device supports : 0x1</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:15 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.1 - Device Descriptor Test (Configuration Index 0) - addressed: Number of: Fails (0); Aborts (0); Warnings (2) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_11'>TD 9.2 - Configuration Descriptor Test (Configuration Index 0) - addressed</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:15 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor contains descriptor of type : 0x4 (Interface Descriptor)</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor contains descriptor of type : 0x21 (HID Descriptor)</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor contains descriptor of type : 0x5 (Endpoint Descriptor)</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of interface descriptors found 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of alternate interface descriptors found : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of endpoint descriptors found : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor length : 0x9</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor type : 0x2</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor TotalLength : 0x22</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor NumInterfaces : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor ConfigurationValue: 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor string descriptor index : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor bmAttributes : 0xA0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device supports remote wake up</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>MaxPower = 50 PowerMultiplier = 2</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Maximum power device requires : 100mA</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device is BUS POWERED</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:16 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.2 - Configuration Descriptor Test (Configuration Index 0) - addressed: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_12'>TD 9.3 Interface Association Descriptor Test (Config 0)</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:16 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'> Device has 1 function, of which 0 have an Interface Association descriptor.</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Function #1 does not have an Interface Association Descriptor.</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'></DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>This device does not contain an Interface Association Descriptor</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:17 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.3 Interface Association Descriptor Test (Config 0): Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_13'>TD 9.4 - Interface Descriptor Test (Configuration Index 0) - addressed</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:17 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Bandwidth check passed</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Testing Interface number : 0x0 Alternate setting : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor length : 0x9</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bDescriptorType : 0x4</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bAlternateSetting : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bNumEndPoints: 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bInterfaceClass reserved for assignment by the USB-IF : 0x3</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface class code indicates [HID] Interface</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface sub class : 1 <not defined></DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface protocol : 2 <not defined></DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bInterfaceSubClass : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bInterfaceProtocol assigned by the USB-IF : 0x2</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor iInterface : 0x0</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:18 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.4 - Interface Descriptor Test (Configuration Index 0) - addressed: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_14'>TD 9.5 - Endpoint Descriptor Test (Configuration Index 0) - addressed</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:18 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'> Testing Interface number : 0x0 Alternate setting : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor length : 0x7</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor type : 0x5</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint Type : Interrupt, Number : 0x1, Direction : IN</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor bmAttributes : 0x3</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor raw MaxPacketSize : 0x8</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor interval : 0x8</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:19 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.5 - Endpoint Descriptor Test (Configuration Index 0) - addressed: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_15'>TD 9.7 - BOS Descriptor Test - Device State Addressed</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:19 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration Index 0x00 has a Configuration Value of 1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>USB Version number of device: 2.00</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device supports version of the USB Protocol that does not support BOS Descriptor</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:20 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.7 - BOS Descriptor Test - Device State Addressed: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_16'>TD 9.1 - Device Descriptor Test (Configuration Index 0) - configured</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:20 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device descriptor length : 0x12</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device descriptor type : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Major version : 0x2</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Minor version : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Each interface specifies its own device class type</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device sub class : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device protocol : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device MaxPacketSize0 : 0x40</DIV></DIV> <DIV class='warn_log'><DIV class='label'>WARNING</DIV><DIV class='content'>Could not open file 'usb.if'.</DIV></DIV> <DIV class='warn_log'><DIV class='label'>WARNING</DIV><DIV class='content'>Failed to get vendor information for VendorID : 0x3F0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device ProductID : 0x4B4A</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device BCD : 0x15</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>ENGLISH_US language string descriptor is : HP</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>ENGLISH_US language string descriptor is : HP USB Fingerprint Mouse</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>ENGLISH_US language string descriptor is : 110103085405161C</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of configurations device supports : 0x1</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:22 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 2 seconds.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.1 - Device Descriptor Test (Configuration Index 0) - configured: Number of: Fails (0); Aborts (0); Warnings (2) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_17'>TD 9.2 - Configuration Descriptor Test (Configuration Index 0) - configured</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:22 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor contains descriptor of type : 0x4 (Interface Descriptor)</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor contains descriptor of type : 0x21 (HID Descriptor)</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor contains descriptor of type : 0x5 (Endpoint Descriptor)</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of interface descriptors found 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of alternate interface descriptors found : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Number of endpoint descriptors found : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor length : 0x9</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor type : 0x2</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor TotalLength : 0x22</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor NumInterfaces : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor ConfigurationValue: 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor string descriptor index : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration descriptor bmAttributes : 0xA0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device supports remote wake up</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>MaxPower = 50 PowerMultiplier = 2</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Maximum power device requires : 100mA</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device is BUS POWERED</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device is currently BUS POWERED</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Currently remote wakeup is DISABLED</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:23 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.2 - Configuration Descriptor Test (Configuration Index 0) - configured: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_18'>TD 9.3 Interface Association Descriptor Test (Config 0)</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:23 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'> Device has 1 function, of which 0 have an Interface Association descriptor.</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Function #1 does not have an Interface Association Descriptor.</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'></DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>This device does not contain an Interface Association Descriptor</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:24 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.3 Interface Association Descriptor Test (Config 0): Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_19'>TD 9.4 - Interface Descriptor Test (Configuration Index 0) - configured</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:24 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Bandwidth check passed</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Testing Interface number : 0x0 Alternate setting : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor length : 0x9</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bDescriptorType : 0x4</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bAlternateSetting : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bNumEndPoints: 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bInterfaceClass reserved for assignment by the USB-IF : 0x3</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface class code indicates [HID] Interface</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface sub class : 1 <not defined></DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface protocol : 2 <not defined></DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bInterfaceSubClass : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor bInterfaceProtocol assigned by the USB-IF : 0x2</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Interface descriptor iInterface : 0x0</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:25 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.4 - Interface Descriptor Test (Configuration Index 0) - configured: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_20'>TD 9.5 - Endpoint Descriptor Test (Configuration Index 0) - configured</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:25 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'> Testing Interface number : 0x0 Alternate setting : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor length : 0x7</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor type : 0x5</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint Type : Interrupt, Number : 0x1, Direction : IN</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor bmAttributes : 0x3</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor raw MaxPacketSize : 0x8</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint descriptor interval : 0x8</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:26 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.5 - Endpoint Descriptor Test (Configuration Index 0) - configured: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_21'>TD 9.7 - BOS Descriptor Test (Configuration Index 0) - Device State Configured</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:26 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Configuration Index 0x00 has a Configuration Value of 1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Initializing the device to the Configured state with Configuration Value 1 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>USB Version number of device: 2.00</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device supports version of the USB Protocol that does not support BOS Descriptor</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:27 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.7 - BOS Descriptor Test (Configuration Index 0) - Device State Configured: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_22'>TD 9.9 - Halt Endpoint Test (Configuration Index 0)</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:27 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Testing Interface number : 0x0 Alternate setting : 0x0</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Testing EndPoint type : Interrupt, Address : 0x81</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint is currently not halted for endpoint 0x81</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Setting feature endpoint halt for endpoint 0x81</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint is halted for endpoint 0x81</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Clearing feature endpoint halt for endpoint 0x81</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Endpoint is no longer halted for endpoint 0x81</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:28 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.9 - Halt Endpoint Test (Configuration Index 0): Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_23'>TD 9.13 - SetConfiguration Test (Configuration Index 0)</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:28 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>SetConfiguration with configuration value : 0x1</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Unconfigured the device</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>SetConfiguration with configuration value : 0x1</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:29 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.13 - SetConfiguration Test (Configuration Index 0): Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_24'>TD 9.14 - Suspend/Resume Test (Configuration Index 0)</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:29 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Suspended the parent port of the Device Under Test.</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Resumed the parent port of the Device Under Test.</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Got device descriptor of Device Under Test</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:31 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 2 seconds.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.14 - Suspend/Resume Test (Configuration Index 0): Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_25'>TD 9.12 - Remote Wakeup Test (Configuration Index 0) - Enabled:</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:31 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Suspended the parent port of the device</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Parent port saw remote wakeup</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Received a remote wake up event</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:39 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 8 seconds.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.12 - Remote Wakeup Test (Configuration Index 0) - Enabled:: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_26'>TD 9.12 - Remote Wakeup Test (Configuration Index 0) - Disabled:</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:39 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Suspended the parent port of the device</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Did not receive a wakeup event on the test device with remote wakeup disabled</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:44 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 5 seconds.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.12 - Remote Wakeup Test (Configuration Index 0) - Disabled:: Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_27'>L1Suspend/Resume Test (Configuration Index 0)</A><DIV class='test-pass'>Passed</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:44 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Checking Device Under Test for LPM L1 Compatibility...</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>USB version of device is 2.00.</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>DUT is NOT compatible with LPM.</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>LPM is NOT required for DUT</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>LPM is only supported in USB version 2.01 and above.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:45 2018</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 1 second.</DIV></DIV> <DIV style='font-weight: bold;color:#007F00'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ L1Suspend/Resume Test (Configuration Index 0): Number of: Fails (0); Aborts (0); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'><A name='anchor_28'>TD 9.16 - Enumeration Test (repeat 150 times)</A><DIV class='test-fail'>Aborted</DIV></DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#0000AA'><DIV class='label'>INFO</DIV><DIV class='content'>Start time: Fri Oct 12 11:23:45 2018 </DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Device speed is Full</DIV></DIV> <DIV style='font-weight: bold'><DIV class='label'>INFO</DIV><DIV class='content'>Beginning enumeration test with 150 enumerations. This may take several minutes to complete.</DIV></DIV> <DIV class='err_log'><DIV class='label'>ERROR</DIV><DIV class='content'>Enumeration failed at iteration 0 (Unknown error)</DIV></DIV> <DIV><DIV class='label'>INFO</DIV><DIV class='content'>Enumerated 0 iterations.</DIV></DIV> <DIV class='err_log'><DIV class='label'>ERROR</DIV><DIV class='content'>A device was not found. Check that device is plugged into correct port.</DIV></DIV> <DIV class='err_log'><DIV class='label'>ERROR</DIV><DIV class='content'>CVHub_ReEnumerateAll20::Enumeration failed</DIV></DIV> <DIV class='err_log'><DIV class='label'>ABORT</DIV><DIV class='content'>Couldn't do full re-enumeration.</DIV></DIV> <DIV class='err_log'><DIV class='label'>FAIL</DIV><DIV class='content'>Test failed</DIV></DIV> <DIV style='font-weight: bold;color:#BF0000'><DIV class='label'>INFO</DIV><DIV class='content'> Stop time: Fri Oct 12 11:23:51 2018</DIV></DIV> <DIV style='font-weight: bold;color:#BF0000'><DIV class='label'>INFO</DIV><DIV class='content'>Duration: 6 seconds.</DIV></DIV> <DIV style='font-weight: bold;color:#BF0000'><DIV class='label'>INFO</DIV><DIV class='content'>Stopping Test [ TD 9.16 - Enumeration Test (repeat 150 times): Number of: Fails (1); Aborts (1); Warnings (0) ] </DIV></DIV> </DIV> <DIV id='test-header'>Display Other Tests To Run</DIV> <DIV class='test-details'> <DIV class='err_log'><DIV class='label'>ABORT</DIV><DIV class='content'>Invalid arguments received</DIV></DIV> </DIV> <DIV id='test-header'>Summary</DIV> <DIV class='test-details'> <DIV style='font-weight: bold;font-style:italic;color:#BF0000'><DIV class='label'>INFO</DIV><DIV class='content'>Summary Log Counts [ Fails (1); Aborts (2); Warnings (6) ]</DIV></DIV> </DIV> </DIV> </BODY></HTML>
the left fig is TUSB2036 HUB (Fail); the right fig is another HUB (PASS)
Driscoll
