This question is specific to a TUSB2036 device In non-ganged mode. If an OVERCUR input is pulled low and the corresponding PWRON output is disabled, will the PWRON output be automatically enabled if the OVERCUR input is pulled high?
Fred
Fred
Thanks for the reply, and I understand that in non-ganged mode, the inputs and outputs are paired. If an OVRCUR input is pulled from low to high, is the PWRON output re-enabled automatically? Are there any control registers or bits in the USB hub that need to be reset to re-enable the PWRON output?
