DS08MB200: how to connect pins of an unused channel
Part Number: DS08MB200
As one channel is unused i will connect the ENABLE signals to GND as stated in the datasheet.
How to connect the differential inputs of the chip, can they be left open?
Are there any recommendations regarding the blocking capacitors on the VCC pins?
  • Hi Thomas,
    Yes connecting the ENABLE signals will disable the output side.
    For the inputs:
    Input Failsafe Biasing
    External pull up and pull down resistors may be used to provide enough of an offset to enable an input failsafe
    under open-circuit conditions. This configuration ties the positive LVDS input pin to VDD thru a pull up resistor
    and the negative LVDS input pin is tied to GND by a pull down resistor. The pull up and pull down resistors
    should be in the 5kΩ range to minimize loading and waveform distortion to the driver.
    For the supply pins:
    I recommend a 0.1uF capacitor for each pin.
    Lee
  • Hi Lee,
    thank you very much for the information.
    Thomas
