My customer is considering about the device behavior when VCC for the receiver IC, AM26LS32AC, is turned off and the input pin is pulled up by output of the driver. Then, the VCC for the driver is applied. Is there any problem in the situation?
Customer worry about that any current flow into VCC line of receiver through the input pin of receiver.
I believe that It's no problem based on internal circuit which is described in the datasheet, if there isn't any additional circuit, ESD circuit or something, in actual device.
Best Regards, Taki
