Other Parts Discussed in Thread: TEST2
My customer meets an issue about SN65DSI186, could you please help me solve this problem? Thanks.
There are two Dell DP, and the timing parameter is the same, but just one can be lightened.
1、Dell SP2318H lightened, EDID,timing and DPCD are:
Dump Panel EDID
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00| 00 ff ff ff ff ff ff 00 10 ac fc a0 53 47 41 32
10| 02 1c 01 04 a5 33 1d 78 3a eb f5 a6 56 51 9c 26
20| 10 50 54 a5 4b 00 71 4f 81 80 a9 c0 d1 c0 01 01
30| 01 01 01 01 01 01 02 3a 80 18 71 38 2d 40 58 2c
40| 45 00 fd 1e 11 00 00 1e 00 00 00 ff 00 34 30 44
50| 34 57 38 31 42 32 41 47 53 0a 00 00 00 fc 00 44
60| 45 4c 4c 20 53 50 32 33 31 38 48 0a 00 00 00 fd
70| 00 38 4c 1e 53 11 01 0a 20 20 20 20 20 20 00 c2
Extract Panel timing from EDID
Pixel Clock : 148500 KHz
XDOT * YDOT : 1920 * 1080
HPW * VPW : 44 * 5
HBP * VBP : 148 * 36
HFP * VFP : 88 * 4
HSYNC: Positive
VSYNC: Positive
Dump Panel DPCD Value
0000h: 11 0a 84 01 01 00 01 00 02 02 06 00 00 00 00 00
0100h: 06 04 00 00 00 00 00 00 01 04 00 00 00 00 00 00
0200h: 01 00 77 11 80 00 00 00 00 00 00 00 00 00 00 00
0210h: ff 7f ff 7f ff 7f ff 7f 10 0a 00 00 00 00 00 00
DPCD: REV:1.1
MAX_LINK_RATE:2.7Gbps
MAX_LINK_LANE:4
Not support ASSR
Not support Enhance framing
2、Dell P2314H can not be lightened, EDID,timing and DPCD are:
Dump Panel EDID
00| 00 ff ff ff ff ff ff 00 10 ac 98 40 4c 57 44 42
10| 1f 19 01 04 a5 33 1d 78 3a e5 95 a6 56 52 9d 27
40| 45 00 fd 1e 11 00 00 1e 00 00 00 ff 00 48 4d 4a
50| 31 56 35 38 31 42 44 57 4c 0a 00 00 00 fc 00 44
60| 45 4c 4c 20 50 32 33 31 34 48 0a 20 00 00 00 fd
70| 00 38 4c 1e 53 11 01 0a 20 20 20 20 20 20 00 a8
HPW * VPW : 44 * 5
HFP * VFP : 88 * 4
HSYNC: Positive
VSYNC: Positive
0000h: 11 0a 84 01 01 00 01 80 02 00 00 00 00 00 00 00
0100h: 0a 82 00 00 00 00 00 00 00 00 0b 00 00 00 00 00
0200h: 41 00 77 00 01 00 00 00 00 00 00 00 00 00 00 00
0210h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DPCD: REV:1.1
MAX_LINK_LANE:4
Not support ASSR
please see the attached files for more details.
-------------------------------------------------- Dump Panel EDID ------------------------------------------------------ 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F ------------------------------------------------------ 00| 00 ff ff ff ff ff ff 00 10 ac 98 40 4c 57 44 42 10| 1f 19 01 04 a5 33 1d 78 3a e5 95 a6 56 52 9d 27 20| 10 50 54 a5 4b 00 71 4f 81 80 a9 c0 d1 c0 01 01 30| 01 01 01 01 01 01 02 3a 80 18 71 38 2d 40 58 2c 40| 45 00 fd 1e 11 00 00 1e 00 00 00 ff 00 48 4d 4a 50| 31 56 35 38 31 42 44 57 4c 0a 00 00 00 fc 00 44 60| 45 4c 4c 20 50 32 33 31 34 48 0a 20 00 00 00 fd 70| 00 38 4c 1e 53 11 01 0a 20 20 20 20 20 20 00 a8 ------------------------------------------------------ Extract Panel timing from EDID ------------------------------------------------------ Pixel Clock : 148500 KHz XDOT * YDOT : 1920 * 1080 HPW * VPW : 44 * 5 HBP * VBP : 148 * 36 HFP * VFP : 88 * 4 HSYNC: Positive VSYNC: Positive ------------------------------------------------------ Dump Panel DPCD Value ------------------------------------------------------ 0000h: 11 0a 84 01 01 00 01 80 02 00 00 00 00 00 00 00 0100h: 0a 82 00 00 00 00 00 00 00 00 0b 00 00 00 00 00 0200h: 41 00 77 00 01 00 00 00 00 00 00 00 00 00 00 00 0210h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------------------------------------------------------ DPCD: REV:1.1 MAX_LINK_RATE:2.7Gbps MAX_LINK_LANE:4 Not support ASSR Not support Enhance framing ------------------------------------------------------
-------------------------------------------------- Dump Panel EDID ------------------------------------------------------ 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F ------------------------------------------------------ 00| 00 ff ff ff ff ff ff 00 10 ac fc a0 53 47 41 32 10| 02 1c 01 04 a5 33 1d 78 3a eb f5 a6 56 51 9c 26 20| 10 50 54 a5 4b 00 71 4f 81 80 a9 c0 d1 c0 01 01 30| 01 01 01 01 01 01 02 3a 80 18 71 38 2d 40 58 2c 40| 45 00 fd 1e 11 00 00 1e 00 00 00 ff 00 34 30 44 50| 34 57 38 31 42 32 41 47 53 0a 00 00 00 fc 00 44 60| 45 4c 4c 20 53 50 32 33 31 38 48 0a 00 00 00 fd 70| 00 38 4c 1e 53 11 01 0a 20 20 20 20 20 20 00 c2 ------------------------------------------------------ Extract Panel timing from EDID ------------------------------------------------------ Pixel Clock : 148500 KHz XDOT * YDOT : 1920 * 1080 HPW * VPW : 44 * 5 HBP * VBP : 148 * 36 HFP * VFP : 88 * 4 HSYNC: Positive VSYNC: Positive ------------------------------------------------------ Dump Panel DPCD Value ------------------------------------------------------ 0000h: 11 0a 84 01 01 00 01 00 02 02 06 00 00 00 00 00 0100h: 06 04 00 00 00 00 00 00 01 04 00 00 00 00 00 00 0200h: 01 00 77 11 80 00 00 00 00 00 00 00 00 00 00 00 0210h: ff 7f ff 7f ff 7f ff 7f 10 0a 00 00 00 00 00 00 ------------------------------------------------------ DPCD: REV:1.1 MAX_LINK_RATE:2.7Gbps MAX_LINK_LANE:4 Not support ASSR Not support Enhance framing ------------------------------------------------------
void SN65DSI86_Init(void) { u8 buf[2]; MIPI2DP_RST_L; Delay_ms(20); MIPI2DP_RST_H; Delay_ms(20); MIPI2DP_Write(0x09, 1, 0x01); Delay_ms(20); MIPI2DP_Write(0x09, 1, 0x00); Delay_ms(20); if(isDual) { MIPI2DP_Write(0x0A, 1, 0x06); //REFCLK 27MHz MIPI2DP_Write(0x10, 1, 0x80); //Dual(Left & Right) 4 DSI lanes MIPI2DP_Write(0x12, 1, 0x32); //DSIA CLK FREQ 222MHz MIPI2DP_Write(0x13, 1, 0x32); //DSIB CLK FREQ 222MHz MIPI2DP_Write(0x94, 1, 0x80); //HBR (2.7Gbps) MIPI2DP_Write(0x0D, 1, 0x01); //PLL DISENABLE Delay_ms(10); MIPI2DP_Write(0x5A, 1, 0x05); MIPI2DP_Write(0x93, 1, 0x24); //2 DP lanes no SSC MIPI2DP_Write(0x95, 1, 0x00); //POST-Cursor2 0dB MIPI2DP_Write(0x96, 1, 0x0A); //Semi-Auto TRAIN DP_Read(); buf[0] = (edp.xdot>>1) & 0xFF; buf[1] = (edp.xdot>>9) & 0xFF; MIPI2DP_Writes(0x20, 2, buf); //CHA_ACTIVE_LINE_LENGTH MIPI2DP_Writes(0x22, 2, buf); //CHB_ACTIVE_LINE_LENGTH } else { MIPI2DP_Write(0x0A, 1, 0x06); //REFCLK 27MHz MIPI2DP_Write(0x10, 1, 0x26); //Single 4 DSI lanes MIPI2DP_Write(0x12, 1, 0x59); //DSIA CLK FREQ 445MHz MIPI2DP_Write(0x13, 1, 0x59); //DSIB CLK FREQ 445MHz MIPI2DP_Write(0x94, 1, 0x80); //HBR (2.7Gbps) MIPI2DP_Write(0x0D, 1, 0x01); //PLL DISENABLE Delay_ms(10); MIPI2DP_Write(0x5A, 1, 0x05); MIPI2DP_Write(0x93, 1, 0x24); //2 DP lanes no SSC MIPI2DP_Write(0x95, 1, 0x00); //POST-Cursor2 0dB MIPI2DP_Write(0x96, 1, 0x0A); //Semi-Auto TRAIN DP_Read(); buf[0] = edp.xdot & 0xFF; buf[1] = (edp.xdot>>8) & 0xFF; MIPI2DP_Writes(0x20, 2, buf); //CHA_ACTIVE_LINE_LENGTH MIPI2DP_Write(0x22, 2, 0x00, 0x00); //CHB_ACTIVE_LINE_LENGTH } buf[0] = edp.ydot & 0xFF; buf[1] = (edp.ydot>>8) & 0xFF; MIPI2DP_Writes(0x24, 2, buf); //CHA_VERTICAL_DISPLAY_SIZE buf[0] = edp.hsync & 0xFF; buf[1] = (edp.hsync>>8) & 0x7F; if(edp.h_pos) buf[1] &= 0x80; MIPI2DP_Writes(0x2C, 2, buf); //CHA_HSYNC_PULSE_WIDTH buf[0] = edp.vsync & 0xFF; buf[1] = (edp.vsync>>8) & 0x7F; if(edp.v_pos) buf[1] &= 0x80; MIPI2DP_Writes(0x30, 2, buf); //CHA_VSYNC_PULSE_WIDTH MIPI2DP_Write(0x34, 1, edp.hbp); //CHA_HORIZONTAL_BACK_PORCH MIPI2DP_Write(0x36, 1, edp.vbp); //CHA_VERTICAL_BACK_PORCH MIPI2DP_Write(0x38, 1, edp.hfp); //CHA_HORIZONTAL_FRONT_PORCH MIPI2DP_Write(0x3A, 1, edp.vfp); //CHA_VERTICAL_FRONT_PORCH MIPI2DP_Write(0x5B, 1, 0x00); //DP 24bpp MIPI2DP_Write(0x5C, 1, 0x00); //HPD DISENABLE MIPI2DP_Write(0x3C, 1, 0x00); //COLOR BAR disabled DPCD_Write(0x00100, 1, 0x0A); Delay_ms(20); MIPI2DP_Write(0x5A, 1, 0x0D); //Enhanced Framing, ASSR, Vstream Delay_ms(10); EDID_Read(); EDID_Print(); Timing_Print(); DPCD_Print(); DPCD_Print_Info(); }
Best Regards.
