Hi team,
1.For the not used channels ,whether float or connect to gnd?
2.For not use EEPROM Case, how about pull up read_en pin to VDD, and float the all_done pin?
Thanks.
Hi team,
Thanks.
Hi Frank,
1). In order to reduce noise propagation, it is better to terminate un-used inputs through 50-Ohm Resistor and AC coupling Capacitors.
2). You are correct. You can pull READ_EN high - through 1K-ohm resistor and leave ALL_DONE floating.
Regards,,nasser
