Other Parts Discussed in Thread: DS90UB954-Q1,
Hi TI,
Our is using DS90UB954-Q1 in our project ,the serializer is DS90UB953 which is work in 4G FPD-Link PoC Network,could you check if the schmatic and PCB layout ?
Peiyuanqing
Hi TI,
Peiyuanqing
Hi Pei,
The in+ and in- should be 100 ohm differential up to the connector so remove the ground trace between. Can they extract the trace loss (s-parameter) of the trace after the layout fix?
