Hi team,
We have three nodes connected in line. The each length is 10M. The resistor is terminated on board. Customer may unplug the wire from the node 3, which cause node 1 and 2 can not work.
How to solve this problem? Thanks
Hi team,
Hi Max,
Is termination present on all three nodes, or on just one or two nodes?
On all three nodes.
When node 3 is removed, is the bus still terminated?
No, the cable is still connected to network.
Have you tried observing the CANH and CANL signals on an oscilloscope to verify the signal quality?
No, please let me if you need it.
