Hello
Customer happen AER issue.
Attached are testing results. A: before tuning re-driver (AER fail as below setting) B. After tuning re-driver (AER Pass as below setting). Customer would like to know the root cause why tuning TX (EQ Level 4 &VOD level 1) and RX ( EQ level 1 & VOD Level 6). The AER issue will be pass. Below is customer questions :
- Could you help clarify why these setting will pass AER? Has any relationship between AER and these EQ/VOD settings ?
- If customer need to setting correct parameters to pass AER, has any tuning reference doc or step to customer to avoid AER issue happen on future? Thank you.
BR
Patrick
