Hi Team,
I am using the TRS3253E : RS-232 Transceiver With Split Supply Pin for Logic Side.
https://www.ti.com/lit/ds/symlink/trs3253e.pdf
In my configuration VCC = VL = 3.3 V and according to the datasheet, in this configuration, the driver Voh (Typ) = +/-5.4V.
In my design I need an higher Voh. can I achieve it by setting VCC = 5V, VL = 3.3 V (the device datasheet do not specify typical values for Vcc = 5V..)?
If not- can you please suggest on a replacement with higher Voh?
Please advise.
Shlomi
