Other Parts Discussed in Thread: TS3L500AE
Hi Sirs,
Sorry to bother you.
We would like to know if we want to increase the 1GbE MDI driving ability, could we use the DS100DF410SQE?
If no have others solution can share?
Thanks!!
Hi Sirs,
Thanks!!
See the programming guide. www.ti.com/.../snla323.pdf
Page 20 Section 3.26 has a programming secquence for RAW mode.
Lee
Hi Sirs,
Thanks for your reply.
So just let me confirm again, DS100DF410 could increase the 1GbE MDI driving ability, right?
The DS100DF410 could provide an increase in the overall MDI interface. The could be achieved by using the Rx equalization. This equalization is optimized for 10 Gbps signals, but it will still provide some benefit to the lower speed 1 GbE signals.
Lee
Hi Sirs,
Actually MDI signal are bi-direction like USB D+/D-, but 410 looks is uni-direct.
So how do we connect if we want to use 410.
By the way, our phy is use Intel I210, actually we discussed with INTEL member and they suggest to add TI LAN mux TS3L500AE.
But we don't see any buffer or re-driver function on TS3L500AE, Could you help to check it?
Sorry you are correct - the MDI interface cannot support a retimer or redriver function due to the bi-directional signals. We often find repeaters used for the SGMII interface.
I currently do not see a solution for this MDI application. The TS3L500AE is a passive mux/switch, it would not provide any equalization or channel extension benefits.
Lee
