Hi Sirs,
Sorry to bother you.
We have using TUSB2077
Some of the MB failed.
In the absence of device state
OVRCUR# is high and PWRON# is also high
That will make TI_TPS2044BDR unable to output power.
I modified the timing of the reset pin
Some fail boards PWRON# will be normal, but others board still fail.
Could you help check it?
Another question
Software reply under a USB flash drive
USB HUB transmission speed is about 959kB/s
Is there a HW strap to fix at high speed??
