Hi
Could you help to check the below figure, i want know the detail time. (RXD green) thanks.
Hi
RXD will transition from high to low after the bus is dominant for the specified filter period (0.5 us minimum, 1.8 us maximum). It will transition from low to high when the bus becomes recessive. So, you could consider the RXD low pulse width to be the bus dominant pulse width minus the filter duration.
Max
