Hi there,
is it possible for the TI933 serializer to handle 1920x1080 YUV422-10bit @30 FPS ?
it is the same question also for the equivalent serializer TI913A.
thank you and best regards,
omar
Hi there,
omar
Hello Omar,
For this video format the 933 and 913A devices will likely not be able to support. The estimated pixel clock is ~140MHz here and the 933/913A can only support up to 100MHz PCLK. You can use this calculator tool to check configurations - please see the tab called "Parallel DVP"
TI Imager-Serializer Data Rate Calculator v2.1 -- Non-NDA.xlsx
Casey
