DP83822I: LINK Issue
Part Number: DP83822I
I am using DP83822.
Sometimes the link does not work when the power is turned on.
The registers for linking and not linking are attached.
Please tell me the cause.
  • Hi Kenji-san,
    The register dump tells me that in the cases with no link, the link partner does not show auto-negotiation capabilities (registers 0x0005 and 0x0006).
    Can you clarify how you are powering the device? The table suggests that you are supplying the device with 3.3V but detecting 1.8V. Am I correct to assume this refers to the VDDIO rails? How are you detecting 1.8V?
    I believe I am already in contact with Motoyasu-san from your team. For better continuity, we may continue this discussion via email.
    Thank you,
    Nikhil
  • Hi Kenji-san,
    I see you have opened a new thread in regards to this issue. For better continuity I will close this thread and continue the conversation here: https://e2e.ti.com/support/interface/f/138/t/881526.
    Thank you,
    Nikhil
