Other Parts Discussed in Thread: TPS65981
While making a custom firmware binary for TPS65982 with TPS65981_2_6_7_8 Application Customization 6.1.1 tool, i found that the bit positions showed in this tool doesn't match the ones in "TPS65981, TPS65982, and TPS65986 Host Interface Technical Reference Manual" http://www.ti.com/lit/ug/slvuan1a/slvuan1a.pdf .
For example :
As seen in the pictures Autonegotiate Variable Sink Enable and Autonegotiate Battery Sink Enable bit positions are swapped.
So the question is , which one to trust? And if the one in the tool is right is there a newer/updated version to the Technical Reference Manual ?
