DS250DF230: IBIS FILES NOT COMPILE
Part Number: DS250DF230
Hi
when i use IBIS files on SigXplorer software , it returns
ERROR - Code file ds250df230_rx_x64.so not found. It was defined in [Algorithmic Model] for Model ds250df230_rx
attached sreenshot :
but this file is located in my directory
can you help me ?
thanks.
    We suspect that the name of the file is incorrect. It is possible that the person on our side who compiled the linux model named it incorrectly.
    You should change the ".so" file name to ds250df230_rx_x64.soThere are two places where you will need to correct it within the TI folder path:
    • TI_DS250DF230_IBIS_AMI_v1 -> Example_Projects-> DS250DF230-> data
    • TI_DS250DF230_IBIS_AMI_v1 -> Model
    Cordially,
    Rodrigo Natal
    HSSC Applications Engineer
