Other Parts Discussed in Thread: TPD3S714-Q1, TPS25221
Hi team,
I want to check whether TPD1S414 supports reverse current block? The internal MOSFET is a single fet or dual fets(back to back)?
Hi team,
Hi team,
If this device cannot support reverse current block, could you recommend another one can support?
This device can't support reverse current block, could you consider TPD3S714-Q1 for your design?
Hi Michael,
Could you suggest a non-auto device with reverse current block in order to replace competitor device RT9746?
TPS25221 support the reverse current blocking function but the voltage only support 5V, I can't find the match device with the RT9746,thanks!
